Results 1 to 14 of 14
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Wide Band O2 Sensors?
    Are these sensors only used for tuning purposes or are they beneficial for full time use?
    Bragg NC
    Met. Sunset Orange
    01 SS
    More for tunning too dial in your A/F ratio's
    J
    Senior Member MadSeason's Avatar
    Indiana
    and after tuning to adjust the amount of fuel going in to correct A/F
    Junior Member BoostJunkie's Avatar
    Chicago
    need an ls1
    nothing, helps you keep accurate track of your a/f ratio
    Indiana
    if it does nothing i invite you to take yours out and tell us how it didnt change a thing as to how your car runs.
    Quote Originally Posted by BoostJunkie View Post
    Chicago
    need an ls1
    i might not have posts but im no newbie when it come to cars, he was asking if it performs any other things other then setting your a/f. and does it? no. explain to me what other features it has
    Indiana
    i already explained it
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    umm ok, how about this. it can act as a narrowband as well as a wideband. you can replace one or both o2s with a wideband and run it/them through a data logger to view both readings.
    Chicago
    need an ls1
    Quote Originally Posted by MadSeason View Post
    that all comes with setting your a/f ratio. i was saying anything other then that. which it doesnt.
    Quote Originally Posted by ninobrn99 View Post
    and what did i say?......... its shows you accurate reading, wideband, narrowband, you just said all it does is shows you the readings
    ok to explain myself better, i know that it acts as an o2, i know you use it as a setting for a car, i think the thread starter knows taht as well. i believe he was asking if it does anything othr then that. which i replied with a no
    Indiana
    gotcha
    Chicago
    need an ls1
    <-- jealous, you have a formula, i want one but i think im gonna end up buying a camaro ss instead, i cant catch a good deal on a bird
    Indiana
    yea its a rare one too just need it fixed
    Chicago
    need an ls1
    whats wrong with it
    Indiana
    whats wrong with it
    here's the bird
    http://edigras.iweb.bsu.edu/FirehawkMain.htm
    here's what happened
    http://edigras.iweb.bsu.edu/savemad.htm
  1. wide band
    By james schofield in forum Computer & Tuning
    Last Post: 02-05-2009, 07:36 AM
  2. Wide Band 02 Reading
    By rossi1369 in forum General Help
    Last Post: 03-30-2008, 08:40 PM
  3. Question: oem wide band?
    By ROCKET1195 in forum GTO
    Last Post: 03-07-2008, 09:17 PM
  4. Which wide band????
    By smoke346 in forum Computer & Tuning
    Last Post: 02-14-2008, 05:11 PM
  5. wide band o2
    By joejenkinsglass in forum Parts Wanted / Trade
    Last Post: 01-27-2008, 05:15 PM
