Thread: Which wide band????
02-13-2008, 06:04 PM #1
Which wide band????
Got HP tuners on the way to the house, any advice on a wideband would be great. Thanks in advance. BTW 02 SS M6
02-14-2008, 10:39 AM #2
I use a wide band from Innovative Motorsports. I've never had any other so I can't compare. But there are others out there. Hopefully others will chime in with their experiences,,,,,but Innovative seems to be a popular choice.
02-14-2008, 03:10 PM #3
I use an innovate LM-1 due to how portable it is but if I was using it on a dedicated car I'd go with the LC-1.
02-14-2008, 04:56 PM #4
Im used to a screwdriver and a timing light to tune a car, this is my first rodeo with FI. So what do you mean when you say portable?? I figured you could wire up the sensor and flip a switch to use it when tuning and turn it off and ues the closed loop for daily driving and such. I might use the HP tuner on my truck, but its a daily driver and I wouldn't expect to use a wideband. So i guess the LC-1 would be fine, but does leaving the sensor in the exhaust all the time shorten its life? Keep in mind I dont drive the SS everyday. Thanks
02-14-2008, 05:11 PM #5
if the sensor is in the exhaust stream it has to be on or it'll foul. A wideband operates completely seperate of your stock narrowbands so you'd have a bung welded into the exhaust and then put the wideband sensor in that bung. I got the LM-1 because it's portable, which means I can move it from car to car. An LC-1 is mounted. If I were you and you're planning on tuning both vehicles I would get the LM-1 so you can move it around when you need to. It's much better to use the wideband when tuning. The bungs come with a screw on cap that you can use to block it off when you don't have the sensor in it.
wide band
By james schofield in forum Computer & TuningReplies: 4Last Post: 02-05-2009, 07:36 AM -
Wide Band 02 Reading
By rossi1369 in forum General HelpReplies: 4Last Post: 03-30-2008, 08:40 PM -
Question: oem wide band?
By ROCKET1195 in forum GTOReplies: 4Last Post: 03-07-2008, 09:17 PM -
wide band o2
By joejenkinsglass in forum Parts Wanted / TradeReplies: 0Last Post: 01-27-2008, 05:15 PM -
Wide Band A/F Tuning??
By crapyboy750 in forum General HelpReplies: 2Last Post: 01-23-2008, 02:27 PM
