Thread: wide band
    grand poobha james schofield's Avatar
    alabama
    tan
    wide band
    I have installed a wide band setup om my 99 ta and the monitor says its 14.1-15.5 up an down at an idle but it smells rich like it should be 9-12. is it normal to be around 14ish at an idle? wot is 12.3-13 what about that?
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    It should toggle either side of 14.7 after the engine is warmed up and in closed loop. 12.3 to 13.0 isn't bad but you need to use a dyno or 1/4 mile times to tell how your doing at WOT.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by james schofield View Post
    If you have no cats, significant camshaft overlap, or both, it's gonna smell. That's why we use a wideband and not our nose to tune
    WOT.... with no dyno, I target 12.8 on the street for most N/A applications.
    alabama
    tan
    thats what I have , so is there anything to worry about? or should I just deal with the smell and ride it?
    yep, just a side effect of the no cats and cam.
  1. Wide Band 02 Reading
    By rossi1369 in forum General Help
    Last Post: 03-30-2008, 08:40 PM
  2. Question: oem wide band?
    By ROCKET1195 in forum GTO
    Last Post: 03-07-2008, 09:17 PM
  3. Which wide band????
    By smoke346 in forum Computer & Tuning
    Last Post: 02-14-2008, 05:11 PM
  4. wide band o2
    By joejenkinsglass in forum Parts Wanted / Trade
    Last Post: 01-27-2008, 05:15 PM
  5. Wide Band A/F Tuning??
    By crapyboy750 in forum General Help
    Last Post: 01-23-2008, 02:27 PM
