Results 1 to 20 of 21
Thread: Door Locks
    Indiana
    2004 GTO
    Door Locks
    My remote key will unlock the driver door but not the passenger door. anybody have any problems like this.
    Member ramrod's Avatar
    Jun 2006
    Roscoe
    GOT BOOST?
    02 Vette-Black 618 rwhp
    Quote Originally Posted by crashkev469 View Post
    Have you tried to rapid it pres it? (anotherwards hit the button twice really fast)
    Retired Outlaw Sum Bitch
    2wice quickly opens both for me.
    Senior Member GOT1GOAT's Avatar
    Newcastle,De.
    04 GTO QuickSilver
    95 MarkVIII wifey white
    Your Personal settings?
    Hi Crash. First,change your user name LOL. Second-is your personal setting set for 1 push for one or for both door locks? There is a choice.
    Press mode-scroll down to 18th item=two stage unlock. If it does'nt work in that setting, take it to dealer fo warranty fix.
    If you have an owners manual,-go to pg.2-35
    Indiana
    2004 GTO
    I have it set to one button. The dealer tells me that they will have to take the doors off and it will cost 800 dollars to check it. I just wanted to see if anybody else had any sort of module/relay problems.
    Newcastle,De.
    04 GTO QuickSilver
    You say 1 button?
    Let me ask you this-Do you have an owners manual?
    Indiana
    2004 GTO
    yes, I have the manual. I know how to set it to one button. The passenger will not work with the remote. The driver side does. I have the lock indicators set off with the computer, but with the passenger door not locking. The horn still goes off when I press lock. But if I manually lock the passenger door, then press lock on the remote to lock the driver door. The indicators don't go off, just the lights flash like they are supposed to.
    Newcastle,De.
    04 GTO QuickSilver
    Just trying to help Bro.
    I am just trying to help you out on this problem crash, especially when the stealership told you $800.00.
    When you say, "I know how to set it to one button', Do you mean One push of the button for both locks? And, if that is the case, this problem should be covered under warranty--unless of course you have over 36,000 miles on it --then you are screwed with the exception of accepting only driver's unlocking and then-you pulling up the passenger 's lock.
    Just one more possibility and this is really out there-unhook your battery,wait a couple of min.s and re-hook then try again.
    I am just trying to help you out Bro. and good-goat-luck.
    04/A4 Quicksilver
    Magnflow catback-Resonator delete
    K&N drop in
    SAP front Grills and 05 hood
    Limo tinted windows-Gets me pulled over alot
    Diablosport Predator (RWTD) tune.
    Indiana
    2004 GTO
    I appreciate everybody's help.
    Newcastle,De.
    04 GTO QuickSilver
    Results yet?
    Hey crash, any luck yet.?
    Member 04goatinmass's Avatar
    salem ma
    04 pontiac gto
    first of all its under warranty so why would they charge you.
    Indiana
    2004 GTO
    Quote Originally Posted by firebird99 View Post
    It's not under warranty, I bought it used with 45k miles for 15000.
    Newcastle,De.
    04 GTO QuickSilver
    Hey Crash. Whats new with your door lock situation?
    Indiana
    2004 GTO
    just waiting on this one. Don't really need to get it fixed right away and I don't feel like getting it broke off in me by the dealers.
    graham nc
    pulse red
    2004 gto
    door locks
    My rh door lock wouldn't work either and it turned out to be a bad lock actuator.
    Member 98 Stang Killer's Avatar
    Channelview, Tx.
    1998 Z28
    im having that problem with driver door i hear it moving but dont lock or un lock think mine is the linkage came undone or something though
    Junior Member gagoat's Avatar
    GA
    torrid red
    04 gto
    as any found a fix for this yet
    alabama
    Gray
    2012 Challenger R/T
    I cant just open both doors from one spot .. If I walk around the car and then try the passenger door opens just fine , or if I open from inside the car it works ... Just food for thought
    Asheville NC
    Brazen Orange
    2006 6.0
    If I hold down the unlock button on my remote both doors will unlock. Just my 2 cents worth
    I had this same issue....it's the actuator. I had mine fixed under warranty but a pretty common issue on the 04's at least.
  1. Door Locks Unlocking On Their Own
    By GULLETT17 in forum Stereo and Electronics
    Last Post: 03-16-2010, 07:11 AM
  2. Power door locks deciding not to work
    By 98ls1t/a in forum General Help
    Last Post: 02-22-2010, 05:23 PM
  3. Help: Power Door Locks
    By jdnoyes in forum Stereo and Electronics
    Last Post: 11-18-2008, 01:27 PM
  4. auto door locks?
    By rgarrett in forum General Help
    Last Post: 10-10-2006, 11:30 PM
  5. problem with door locks
    By blk_jaws in forum Stereo and Electronics
    Last Post: 11-15-2005, 12:46 PM
