Results 1 to 10 of 10
03-15-2010, 09:10 AM #1Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
Door Locks Unlocking On Their Own
I have an odd little problem. . . My door locks repeatedly try to unlock while driving down the road, like someones playin with the remote. It seems like they're only trying to do this while the ignition is turn on, so security's not really an issue, just annoyance. To me, it seems like a something wrong with the remote sensor or a bad ground. Anyone ever experience this? Where is the remote sensor located?
03-15-2010, 09:28 AM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
a ghost maybe ?
..i have never heard of this...subscribed to see an answer
03-15-2010, 09:32 AM #3Senior Member
- Oct 2007
- Muncie, IN
yeah it is pretty creepy
03-15-2010, 10:07 AM #4
BCM problem i'm thinking..
03-15-2010, 10:09 AM #5
Our key fob is a radio transmitter. I'm not sure where the reciever is. Sorry.
03-15-2010, 02:23 PM #6Senior Member
- Feb 2006
- Orange County, NY
Start with checking your battery voltage and connections.
03-15-2010, 03:10 PM #7None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Could be a bad power lock switch as well. The spring that returns the switch could be worn and while driving it would be like you're pushing it. Just something to check.
03-15-2010, 03:34 PM #8
I had this problem except mine just kept locking and locked my keys in anytime the door closed. i traced it to the driver's side door switch, water dripped on it from the t-top when driving at highway speed and fried something i guess. i just cut the ground to the switch b/c i never lock my doors with the door switch anyway just the remote. no problems since..
2000 Z28 M6 125,XXX: SLP lid, K&N, 10.4mm Taylor plug wires, Frost Tune, P&P TB, NGK Iridium plugs, Magnaflow Cat back, BMR SFC's and tower brace, TSP LT's and ORY, LS6 intake, MAC Girdle, UMI LCA's and Panhard, LS7 Clutch Kit, so far..
03-15-2010, 04:54 PM #9Member
- Tulsa,OK
Quick Silver- 2002 Z06
This is interesting, I think the switch would be the easiest thing to test. You can look at the window motor replacment instructions by following the link in my sig if you are unsure how to remove the switch bezel.
Just unplug one for a day and see if it stops. Otherwise I think Smittro is right on the money...
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
03-16-2010, 07:11 AM #10Senior Member
- Oct 2007
- Muncie, IN
thanks fellas . . im gonna start with checkin the switch tonight . .
unlocking 2002 camaro door
By bipolar420 in forum General HelpReplies: 7Last Post: 04-03-2013, 03:11 PM -
Help: Power Door Locks
By jdnoyes in forum Stereo and ElectronicsReplies: 3Last Post: 11-18-2008, 01:27 PM -
Door Locks
By crashkev469 in forum GTOReplies: 20Last Post: 09-10-2008, 05:39 PM -
auto door locks?
By rgarrett in forum General HelpReplies: 4Last Post: 10-10-2006, 11:30 PM -
problem with door locks
By blk_jaws in forum Stereo and ElectronicsReplies: 5Last Post: 11-15-2005, 12:46 PM
