    Junior Member 98ls1t/a's Avatar
    Sep 2008
    Massachusettes
    Bright Red
    1998 Pontiac Trans AM
    Power door locks deciding not to work
    Power door locks deciding not to work. Does anyone know where the relay switch is?
    Junior Member jpn8801's Avatar
    SoCal
    2000 Trans Am WS.6
    NO, sorry man! I am having the same issue with mine, the driverside will not lock or unluck. i figure it just went out but i dunno.....
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Is it just the locks? The windows still work fine? Is it one side? Have you tried the pass switch?
    Sep 2008
    Massachusettes
    Bright Red
    Ive tried all the switches and the windows work fine.
    Member lsgunner28's Avatar
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    When I first got my car the locks would freak out and just keep locking, I finally figured out that while driving in the rain at highway speed it would drip at the corner of the t-top and right onto the driver side switch. So I pulled it out and cut the ground to the switch, no problems since and I forgot about it because I never lock my doors from my car door switch, only the keys. Might be worth checking.. The fuse too!
    2000 Z28 M6 125,XXX: SLP lid, K&N, 10.4mm Taylor plug wires, Frost Tune, P&P TB, NGK Iridium plugs, Magnaflow Cat back, BMR SFC's and tower brace, TSP LT's and ORY, LS6 intake, MAC Girdle, UMI LCA's and Panhard, LS7 Clutch Kit, so far..
    Pittsburgh
    2008 Hummer H3
    Could be a BCM issue starting to arise. BCM trouble is very common in our cars..
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by 98ls1t/a View Post
    The lock relays are in the BCM. You can also check the "Courtesy" fuse in the IP fuse block and check for a good ground on the Black wire at the lock switch. That black wire connects to the ground called G200 which is "Near the left A-pillar, bolted to the instrument panel mounting stud behind the kick panel" according to the service manual.
  1. Power door lock doesn't work on drivers door..
    By 99RedTa6spd in forum Firebird / WS6
    Last Post: 09-03-2014, 08:20 AM
  2. Door Locks Unlocking On Their Own
    By GULLETT17 in forum Stereo and Electronics
    Last Post: 03-16-2010, 07:11 AM
  3. Help: Power Door Locks
    By jdnoyes in forum Stereo and Electronics
    Last Post: 11-18-2008, 01:27 PM
  4. Door Locks
    By crashkev469 in forum GTO
    Last Post: 09-10-2008, 05:39 PM
  5. auto door locks?
    By rgarrett in forum General Help
    Last Post: 10-10-2006, 11:30 PM
