Results 1 to 13 of 13
    south bend, IN
    1994 camaro z28
    What size are the stock injectors?
    What size are the stock injectors on a '94 z28 lt1? Thanks.
    south bend, IN
    1994 camaro z28
    Also, will the ford or venom universals fit in place of the stockers?
    Aug 2006
    Missouri
    94 Camaro Z28
    I think the stock injectors are 24lb/h. I think GM upped the size from the 93. As far as the Ford Universals, I think they do. I know a guy on automotiveforums.com (yes, I post there too, just different name) that uses Ford 33lb/h injectors. NOt sure if he needed modifications to anything, but yes they work.
    Aug 2006
    trevose pa
    94 z28
    correct 94 up are 24lb
    Senior Member 440 rwhp trans am's Avatar
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    no i know they are 19 on the trans am and camaro for those years
    Aug 2006
    trevose pa
    94 z28
    I may be mistaken(wouldn't be the first time) but I'm pretty sure it was 22lb (1992-1993) and 24lb (1994-1997)
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    i just took mine off my 97 trans am 5.7 and they were 19 i put 30 on there. fun until you fill up
    Aug 2006
    Missouri
    94 Camaro Z28
    Nope, 94 and up had 24's from the factory. I don't know who f-ed up your TA, but it should have had 24's in it.
    http://www.danszs.freeservers.com/camaro.htm
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    that may have been the reason i was running lean! lol
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    now in runnung rich! hahahaha
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by 440 rwhp trans am View Post
    Sounds like you need to get a tune for those new injectors. No need to be shooting fireballs out of the exhaust.
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    Quote Originally Posted by BlackLT1Z28 View Post
    yes i do i just posted a thread for help
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
  1. Help: what size injectors..need help
    By badta98 in forum External Engine
    Last Post: 05-21-2011, 04:17 AM
  2. Question: Which size injectors should I get for cam ls1? 48?
    By allbaugh_04 in forum General Help
    Last Post: 04-29-2010, 07:16 AM
  3. injectors what size?
    By lilicedout24 in forum External Engine
    Last Post: 12-24-2005, 01:58 PM
  4. what size injectors?on set up
    By lilicedout24 in forum Internal Engine
    Last Post: 12-19-2005, 10:05 PM
