Results 1 to 20 of 35
    Omaha, NE
    2000 Z28 Camaro
    Which size injectors should I get for cam ls1? 48?
    I have stock injectors and I have them ready to ship to a company that can make them up to 48lb by changing the discharge plate.
    Some say with the right tuner, you can use just about any size and they will make them work? Is this true? Should I just make them 48lb?
    I have full bolt-ons and a cam. So 36lb or so should be enough, but I might use nitrous in the future...should I just make them 48lb and let the tuner do his job?
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    99 camaro
    03 cobras have 39's, mine made 500rwhp and still had some inj duty left.
    Omaha, NE
    2000 Z28 Camaro
    The main thing I need to know is if the right tuner can make em work...Then I'll just get 48lb so i can be ready for the future.
    Anyone know?
    Oct 2009
    arkansas
    99 camaro
    I have hp tuners and it will change em if ya know how. its just simple math and then using a multiplier in the injector table.
    Omaha, NE
    2000 Z28 Camaro
    Quote Originally Posted by JRENIGAR View Post
    OK thanks, I'm sure my tuner knows what he's doin then.
    Thanks for your help.
    Oct 2009
    arkansas
    99 camaro
    I havent checked what the max injecto size it will adjust for is but surely it will go that high or higher.
    Kentucky
    S O M
    2002 Camaro SS
    If you're having a reputable service like FIC resize your oem injectors, and check for flow balance it is a simple matter to change the injector flow rate and the other parameters such as voltage offset remain stock.
    One thing to remember is that Ford injectors are rated at 42 PSI (3 bar) and GM are rated at 58 PSI (4 Bar), so you have to make sure you compare sizes at the same PSI.
    I think I had my oem gm injectors resized to 38 lb/hr at 3 bar and I have right at 500 hp at the wheels.
    2002 Camaro 11.828 @ 119.88 3900 lbs with me in the seat.
    2004 Z06 for Road Courses.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    If you plan on a dry shot, I'd go with the 48's !!!
    Omaha, NE
    2000 Z28 Camaro
    Quote Originally Posted by KP1 View Post
    One thing to remember is that Ford injectors are rated at 42 PSI (2 bar) and GM are rated at 58 PSI (3 Bar), so you have to make sure you compare sizes at the same PSI.
    I think I had my oem gm injectors resized to 38 lb/hr at 2 bar and I have right at 500 hp at the wheels.
    Yep, I'm having FIC do em.
    Quote Originally Posted by bills98ta View Post
    I did go with 48
    NC
    SOM
    1998 T.A.
    It is actually 3 bar and 4 bar...... I have 42lb Bosch design III's that flow 48lb's at 4 bar FWIW......
    South Carolina
    1998 Z28 Camaro
    I mean is it sad to say that I have a head and cam ls402 and still using the stock 98' injectors
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by SOMbitch View Post
    Thanks for clarifying that. I thought it was 3 and 4 also.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by dude2000_22222 View Post
    yes
    South Carolina
    1998 Z28 Camaro
    I mean what would be the reason to upgrade I don't think you would see any performance increase?
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    I would love to see your injector duty cycle from ~4500ish RPM and up. Do you know what it is?
    Omaha, NE
    2000 Z28 Camaro
    The cam is bringing in more air so i need injectors that can keep up. That's all.
    Kentucky
    S O M
    2002 Camaro SS
    You're right. Corrected.
    South Carolina
    1998 Z28 Camaro
    To be honest I didn't even think to ask the tuner about it. But to come to think of it the car's hp curve dies around 5200 rpms and he could not figure out why. He just assumed I needed better heads but could it be the injectors?
    Omaha, NE
    2000 Z28 Camaro
    What year is your LS1? What are your mods?
    South Carolina
    1998 Z28 Camaro
    Its a slp 402 with a 236/236 cam, headers, 98' heads heavily worked, bigger valves, ls6 intake. The car makes around 445rwhp and 460trq. But the power curve dies at 5200 or 5400. He believes its the heads but unless my flow charts are lying I think they flow fairly well. He says it should be around 500 at the wheels easy.
  1. Help: what size injectors..need help
    By badta98 in forum External Engine
    Last Post: 05-21-2011, 04:17 AM
  2. what size injectors should I run?
    By glock22_40 in forum LT1
    Last Post: 09-15-2006, 07:51 PM
  3. injectors what size?
    By lilicedout24 in forum External Engine
    Last Post: 12-24-2005, 01:58 PM
  4. what size injectors?on set up
    By lilicedout24 in forum Internal Engine
    Last Post: 12-19-2005, 10:05 PM
