    Member Jon7I2's Avatar
    Chicago
    99 Formula M6
    Stoping Y-pipe rattle w/o melting
    After recent longtube/Y-pipe install I have been experiencing some rattling. I know exactly what it is, and where it is comming from. It is the driver side of the Y-pipe hitting the transmission crosmember tab. Now is there something i could stick in there to stop this w/o it melting. Perhaps like a high temp. foam or foam wrapped in high temp. duct tape or something else im not even thinking of. Any ideas would help a lot.
    South of Heaven
    Navy Blue Metallic (NBM)
    2002 Camaro SS
    I use heater hose held on with 2 - 3 1/2" hose clamps at either end of the hose that is wedged between the y-pipe and floorboard. The heater hose does break down though... I thought about trying to use a header wrap next...
    Chicago
    99 Formula M6
    What exactly is a header wrap? will it stay resistant to the heat?
    South of Heaven
    2002 Camaro SS
    Have you guys tried loosening your exhaust up and adjusting it? I had problems with the Y hitting and finally got under there and loosened the exhaust all the way back to where it went over the axle. I adjusted it and tightened everything back down and all is good. I tried just adjusting the Y pipe first but that didn't help. I had to loosen the intermediate pipe also because that angle is critical.
    South of Heaven
    2002 Camaro SS
    Darn good point, but I had to Sawzall my stock y-pipe off and when I went to get it patch welded they welded the whole system together headers/ORY/I-pipe, so I am FUBAR with that. Will have to sawzall when the time comes to remove or replace...
    Pittsburgh
    Quote Originally Posted by Azrael View Post
    8th product down cured my banging.
    02 TA A4
    408ci - 244/250/612/622 | PRC 237 heads | FTRA |100mm lid | FAST92/92 | Kooks 1 7/8 | Hooker CB | DMH Cutout | built trans | Yank4000 | 412 motorsports tuned | stock rear:judge:
    08 TBSS - Borla CB
    Junior Member murray01's Avatar
    Arkansas
    01 z28
    I used an old fireman's glove on mine.
    Marylandistan
    2001 Trans Am (sold)
    Use a piece of rubber hose between the crossmember and the y pipe, run a screw clamp thru the hose around the y pipe.
    South of Heaven
    2002 Camaro SS
    Quote Originally Posted by onyx_rock View Post
    If you can unbolt your y-pipe definately get the bump stop!
    98 trans am F-Bomb's Avatar
    Aug 2006
    plano, Tx
    chameleon
    98 T/A
    i took mine to the local muffler shop and had him heat it up ever so slightly no bang here my only thing now is the o2 sstems rattle like a diamond back! any one got a cure for that crap.
    Member Fedge's Avatar
    Feb 2006
    New Jersey
    1998 Trans Am M6
    where does that bolt to? i'm about to do LTs and ORY and don't want it to rattle
    95 Exploder
    01 R1 coming?
  1. Hydrolocked from melting snow??????
    By Z28dryva in forum Internal Engine
    Last Post: 04-24-2013, 08:13 AM
  2. Made my own Y pipe ANti-rattle solution!!! PIC
    By 5abivt in forum External Engine
    Last Post: 05-11-2010, 09:18 AM
  3. smacked y-pipe now lots of rattle and vibrations
    By Z28boy2000 in forum External Engine
    Last Post: 07-19-2009, 07:08 PM
  4. Tire melting 101
    By JJWON in forum Almost Anything Goes
    Last Post: 03-29-2008, 09:12 AM
  5. tailight is melting!!!!
    By bluefields88 in forum Stereo and Electronics
    Last Post: 02-24-2007, 01:42 AM
