05-10-2010, 08:52 AM #1Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Made my own Y pipe ANti-rattle solution!!! PIC
So, I installed a Hooker 3" Y and corsa cat back to the stock exhaust behind the cats a while back. I had tons of rattle. I bought an anti rattle bracket from somewhere and it worked to some degree but not 100%. ANytime there was a little hop it was back with a vengeance.
Can't really blame the clamp. I bought the 3" because I assumed it fit on the Y pipe. My Y was fitted further back so I still had dinky 2.5 inch pipe where it was supposed to clamp the pipe. I ended up using exhaust wrap to make up the .5.
Anyhow, To work effectively I had to push the pipe far from the floor to tighten the clamp and it reduced clearance. After a few bad speed bumps scraped and destroyed the clamp it pretty much just hung there. WHile I had the car up to do the coilovers and shocks I decided to do Some McGivering and figure some way to stop rattle.
This works 100%. ZERO rattle at all times even under aggressive driving. I slit the rubbers and slid them on the clamp. Between the exhaust pipe and the rubber I wrapped a layer of exhaust wrap so the rubber wouldnt melt. Looks pretty ghetto but great clearance (for now until headers arrive anyways) and no rattle whatsoever !!! There's 2 rubbers in there one you can't see on the inside.
I know the wrap is raggedy but I just reused a piece I had on the pipe before instead of just cutting new one. I was lying under the car and was too lazy to get up lol.
05-10-2010, 09:19 AM #2
Nice fix -- be curious to see if it holds up to the heat. If my Y bangs, I will be trying the bracket first, but will keep this in mind.
05-10-2010, 09:39 AM #3Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Here's the original clamp.
Im not sure but i would imagine if you use the clamp in it's intended location and it doesn't work you would probably need to get one .5" bigger than the pipe to be able to fit some heat shielding or exhaust wrap and a piece of rubber in there. Cool thing is it can be placed anywhere. i did smell a faint bit of rubber after the first drive but after a few days of driving I wiggled it and its fine and no more smell. this pic was taken last night after a few days. If heat does kill it, I'll probably get more muffler hanger rubbers from anywhere, and move the clamp further back down the exhaust stream and place 2 layers of heat shielding or some foil paper too. Pretty ghetto but I was shocked at how effective it works this way. I drove like a maniac to work this morning and I couldn't get it to make any sort of noise or vibration from underneath at all.
It's just a temporary fix although one of the main reasons I ordered headers was to eliminate the rattle. I have poly mounts etc which will be installed with the headers too. On the bright side if there still is rattle after the install I know how to stop it.Last edited by 5abivt; 05-10-2010 at 09:42 AM.
05-11-2010, 06:31 AM #4Senior Member
- Jan 2010
- texas
silver- 2000 formula
with polys..........my engine does not rock a milli meter............no Y pipe bang there
05-11-2010, 09:18 AM #5Member
- May 2009
- Manitoba
blue- 1998 Trans Am ls1
Made in The World labels, Made in USA not allowed.
By KahanaReef in forum Political / Debate ForumReplies: 4Last Post: 06-12-2012, 10:20 AM -
Help: Rattle/Clanging Sound in Rear and False Anti Lock/Low Tract
By GULLETT17 in forum DrivetrainReplies: 3Last Post: 09-19-2011, 04:46 AM -
new lt headers and ory pipe installed, made car slower?
By jackmajic in forum General HelpReplies: 21Last Post: 08-14-2011, 04:52 PM -
smacked y-pipe now lots of rattle and vibrations
By Z28boy2000 in forum External EngineReplies: 4Last Post: 07-19-2009, 07:08 PM -
Stoping Y-pipe rattle w/o melting
By Jon7I2 in forum External EngineReplies: 11Last Post: 08-25-2006, 07:18 AM
