Results 1 to 20 of 31
    Berkeley, CA
    2000 Camaro SS #3574 A4
    tailight is melting!!!!
    my left brakelight has a huge dip in it right across from the bigger light bulb. I took it all out and looked at the bulb and it was black on one side yet not burnt out. and the tan socket is was in had brown-burnt edges on it. I replaced the bulb with a new one and my brother felt the bulb while I held down the brake pedal and said it got rediculously hot in just a couple seconds. my right brakelight doesn't have this problem. what's up with this?
    Houston Tx.
    Blue
    00ss
    Cool
    You have a short somewhere.....
    Are you running blackouts on your taillights?
    Painted manta stripe
    Berkeley, CA
    my taillights are stock, haven't done anything to any of my lights except replace a blinker bulb in the front.
    Berkeley, CA
    Quote Originally Posted by shitzNgetz View Post
    well, I did have some Infinity 62.7i door speakers installed, and a new driver window motor. that's the only electrical stuff done to the whole car I beleive.
    Member {FzS}BlacKMagicK's Avatar
    Florida
    BlacK
    2001 WS6
    Note to self: Change all bulbs to LED's ASAP!
    Houston Tx.
    Blue
    00ss
    Cool
    Speakers wouldn't have anything to do with it....
    Is it only one bulb that's getting hot?
    Berkeley, CA
    ya, just the driver side at the moment. and I was wondering about the LEDs. can I get some and still use the stock taillight assemblies?
    Houston Tx.
    Blue
    00ss
    Cool
    Yes, you can use LED's with OEM tails.....
    First fix the problem you're having, then you can do whatever you want....
    You're sure that you are using the correct bulb, right?
    Is the socket rusted or corroded on the inside?
    Berkeley, CA
    I looked in the booklet and it said that the bulbs were the correct replacements. and there wasn't any rust or corrosionin the socket.
    Houston Tx.
    Blue
    00ss
    Cool
    Bulbs do get hot, you do know dat?
    Check all your other sockets too, on both sides.......
    Everythig else works fine as far as the turn signals, etc., right?
    Just replace both sides with the new bulbs and let's take it from there.....
    Let me know tomorrow.
    Laters!!!!!!!!
    Berkeley, CA
    let me start this post with one of these: .
    well I found the problem. and it was a wrong light bulb. the old one that was all hot was a 3157 bulb. the stop lights are supposed to be 3057's. I didn't notice the number difference since I only glanced my manual. I thought the bulbs were originals, but I guess they weren't. I just went and bought the correct 3057 bulbs, and thought I'd check out the right hand side bulbs. turns out the one on the right was a 4157 K. glad I checked. I ended up checking all the rest of the bulbs while I was at it to make sure the old owners didn't mess any of those up. they were all good except the two brake light bulbs. so what do the numbers stand for anyways? is a 3157 hotter than a 3057?
    Houston Tx.
    Blue
    00ss
    Thumbs up
    well I found the problem. and it was a wrong light bulb. the old one that was all hot was a 3157 bulb. the stop lights are supposed to be 3057's. I didn't notice the number difference since I only glanced my manuel. I thought the bulbs were originals, but I guess they weren't. I just went and bought the correct 3057 bulbs, and thought I'd check out the right hand side bulbs. turns out the one on the right was a 4157 K. glad I checked. I ended up checking all the rest of the bulbs while I was at it to make sure the old owners didn't mess any of those up. they were all good except the two brake light bulbs. so what do the numbers stand for anyways? is a 3157 hotter than a 3057?
    I told ya!!!!!!!!!!!!!!! lol
    Good deal.
    Berkeley, CA
    ya, thanks for the help! now it's time for LED's. . any idea where I can pick some up and for how much?
    Houston Tx.
    Blue
    00ss
    Cool
    Try these guys out.
    http://www.lunaraccents.com/index.htm
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    I'd like to know too so I don't ever have to change a bulb again or maybe until I'm like 50!
    Berkeley, CA
    can you buy LED lights that plug into the stock sockets? I know absolutely nothing on the subject.
    Houston Tx.
    Blue
    00ss
    Cool
    http://superlumination.com/3157_3156.htm
    http://www.discountleds.com/
    Berkeley, CA
    so just to make sure that I found the problem, could putting a 3157 bulb in a 3057's socket cause it to make all the heat that melted my taillight? or should I look for a short.
    Houston Tx.
    Blue
    00ss
    Cool
    Check the chart out or give them a call with your Q if you're still not sure....
  1. Question: Blacked out tailight question
    By claytonr in forum Camaro / SS
    Last Post: 10-16-2008, 05:18 PM
  2. Question: Tailight Blackouts
    By BLKBRDTA in forum Appearance Section
    Last Post: 07-21-2008, 12:52 PM
  3. whistler c5 tailight mod
    By myzisbetter in forum Camaro / SS
    Last Post: 05-30-2008, 01:11 AM
  4. Tailight tinting
    By high pressure in forum Appearance Section
    Last Post: 02-16-2007, 09:19 AM
  5. Dim tailight
    By Unlimited in forum Stereo and Electronics
    Last Post: 04-28-2006, 03:32 PM
