08-21-2006, 03:09 PM #1
Couple questions about everyones oil pressure and temp
Ive had my car about 6 months and was wondering what everyones oil pressure runs at after being ran for a while. Also what is the temperature that they run at. One more question....there is a 3/4 bypass cap on the bottom drivers side of my radiator and it recently busted while I was driving. I was wondering if it was supposed to go anywhere or are they all that way. My car runs at about 185 down the road and about 195-200 at an idle in drive. The oil pressure is about 45 running down the road and 20-30 at an idle.
08-21-2006, 04:52 PM #2
20 psi seems a bit low, Your pump runs off your motor, so the higher the rpm the more pressure you should have. Temp seems about right but keep in mind these gauges arent the most accurate. How many miles are on the ls1?
08-21-2006, 04:53 PM #3
08-21-2006, 04:54 PM #4
lol
J
08-21-2006, 04:56 PM #5
82,000 miles the oil pressure ranges from 20-30 while in drive at a complete stop and the oil pump is inside of the timing cover. So i guess when i do my finally do a cam swap ill change the oil pump
08-22-2006, 03:26 PM #6
I would say that at that mileage at idle and fully warmed up 20 - 30 would be fine. What weight oil are you using? You could switch to 10w 30 if you are running 5w30 right now-would give a higher oil pressure reading. For racing engines they look for 10 psi per 1000 rpm.
08-22-2006, 04:11 PM #7
08-22-2006, 04:14 PM #8Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Your good kid....no problems with any of the numbers you posted.
Oil temp/pressure question.
By Young11b in forum Internal EngineReplies: 11Last Post: 08-29-2012, 12:13 AM -
Water Temp and Oil Pressure Gauges
By Z28boy2000 in forum Parts For Sale / TradeReplies: 1Last Post: 07-14-2010, 08:16 PM -
Coolant Temp and Oil Pressure question
By johnnybz28 in forum General HelpReplies: 19Last Post: 03-17-2010, 10:57 AM -
Question: oil pressure and water temp?
By mark21742 in forum GTOReplies: 16Last Post: 09-10-2009, 06:43 PM -
Finally, the answer to everyones questions
By Z28_SS in forum Camaro / SSReplies: 3Last Post: 05-01-2007, 07:36 PM
