Results 1 to 20 of 20
    Oct 2009
    queens, ny
    2002 Camaro Z28
    Coolant Temp and Oil Pressure question
    Here is a pic of what my car idles at, is it normal? Should I install a 160 thermostat?
    2002 Camaro Z28
    Mods: PRC Stage 1 LS6 heads and 225/229 .580/.590 114+4 LSA Cam; LS2 timing chain
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Looks normal to me. If you have a stock thermostat you should be at 180-190. Oil should be around 40 psi.
    Oct 2009
    queens, ny
    2002 Camaro Z28
    Thanks I should be ordering a 160 within the next week. Don't like the temps that high at all lol
    North Jersey
    2004 GTO M6
    With the mods you have, I am surprised you don't run a 160.
    Oct 2009
    queens, ny
    2002 Camaro Z28
    The mods were actually just finished last week
    Pittsburgh
    2008 Hummer H3
    My 3800-II used to run there too. I moved to a 5w30 motor oil from 10w30 (factory) and see consistanly lower temps.. say 180-190ish..
    Your oil pressure looks normal..
    Tulsa,OK
    Quick Silver
    2002 Z06
    That looks normal to me also... Did you do a before and after dyno by chance?
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Perfectly normal. That temp gauge is horribly inaccurate. It basically reads, Cold/Warm/Hot.
    Build in progress...
    Oct 2009
    queens, ny
    2002 Camaro Z28
    Quote Originally Posted by gnomee View Post
    I need to have my injectors installed before I dyno and get a new tune. Should hit a dyno within the next couple of weeks.
    With just long tubes, ory, catback and a lid the car made 343rwhp 358rwtq (dyno jet numbers)
    Marion, South Australia
    Sandstone
    09 VE Omega Int Dual Fuel
    It's not really efficient to run the engines too cool and in my view, 160 degree F is not too high - remember the system is pressurised so normal 212 Boiling Point is much higher under pressure.
    Mike
    NC
    1998Z28
    Leave the 180 alone. Thats not the real temp. anyway you got a 2002.
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    Oct 2009
    queens, ny
    2002 Camaro Z28
    Quote Originally Posted by PFM View Post
    not 100% sure what you mean lol
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    When you get your tune, you can have them also change when your fans come on to work better with your 160 thermo.
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    your idle speed is high i dont have the mods you have but my idle is about 600
    NC
    1998Z28
    1998 is the only year that the readings are accurate. They have the 3 wire connectors like the 97-98 vettes. 2002s read basically cold/warm/hot and only have a 2 wire connector. So your getting worried over nothing.
    Oct 2009
    queens, ny
    2002 Camaro Z28
    gotcha
    Oct 2009
    queens, ny
    2002 Camaro Z28
    Quote Originally Posted by twozs View Post
    its still needs to get retuned because right now my stock injectors are working over time lol
    +2 (or whatever) on the factory temp gauge being a POS. Our car is equipped with a 180 degree thermostat and has reprogrammed fan settings. On my scanner, the engine temp will range from 183 to 195 depending upon load and speed. In contrast, the factory temp gauge always reads right around 205.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Factory temp gauge (1999 and newer) = Off (pointing to the left); On and running (straight up and down); OH SHIT IT'S GONNA BLOW! (self explanatory)
    Chevy did this in response to customer concerns over the temp needle moving back and forth in response to the thermal cycling of the coolant. Some fix, huh?
    Tulsa,OK
    Quick Silver
    2002 Z06
    Can't fix stupid but you can fool so you don't have to deal with it
  1. Oil temp/pressure question.
    By Young11b in forum Internal Engine
    Last Post: 08-29-2012, 12:13 AM
  2. 98 Z-28 coolant temp sensor question
    By lsruthles in forum External Engine
    Last Post: 12-15-2011, 03:41 PM
  3. coolant temp??
    By brendan.9 in forum Corvette
    Last Post: 07-24-2010, 07:59 PM
  4. Low coolant... temp is UP!!!
    By The_Wretched in forum General Help
    Last Post: 11-28-2008, 12:13 AM
  5. Coolant temp sensor
    By shaggsm3ls1 in forum Firebird / WS6
    Last Post: 11-15-2008, 05:00 PM
