Results 1 to 17 of 17
Thread: oil pressure and water temp?
09-07-2009, 08:32 AM #1
hey I've searched and can't it a wiring diagram....I'm hooking up an Autometer electric oil pressure and water temp gauges and was going to tie into the stock harness if I can.
does any have a wiring diagram for an 04 GTO?
09-07-2009, 08:43 AM #211 years of bangin gears
- Jan 2009
- North Jersey
See...this is why I wish us 04 owners had the setup like the 05/6. Plug under the dash where the center gauge pod goes.
09-07-2009, 09:16 AM #3
09-08-2009, 08:20 AM #4
Mark, why dont you just buy a sandwich adaptor for your oil filter? I just did this, it comes with 4 1/8 NPT ports for your pressure sender and takes minutes to install. Check out the general help section, I posted a few pictures of it in a thread there.
09-08-2009, 09:23 AM #5
09-08-2009, 09:27 AM #6
I ran several wires through a rubber plug in the firewall that is VERY easy to get to on both sides, on the drivers side just below the brake booster (might be the clutch mounting hole?) mine is an auto
09-08-2009, 10:39 AM #7
I think you GTO guys are blessed with holes then
What guages did you go with? Cool you got it t-ed in
09-08-2009, 12:12 PM #811 years of bangin gears
- Jan 2009
- North Jersey
When I do mine, I think I'll get a vacuum and an AFR gauge.
09-08-2009, 05:31 PM #9
09-08-2009, 05:33 PM #10
09-08-2009, 05:35 PM #11
09-08-2009, 05:41 PM #12
09-08-2009, 09:45 PM #13
09-08-2009, 10:30 PM #14
I pulled out the stock double DIN cd player and put in a single DIN Sony.....made a panel to fill the hole under it and mounted my A/F gauge there.....im going to pull it out and make a new panel to hold three guages (A/F, oil pressure, volt) and the two tranny mode switches. I also mounted the shift light right at the base of the A pillar pointing right at my eyes.
I have a 2 gauge A pillar pod laying in the garage I'll add later when I get the gauges to fill them (maybe trans temp, oil temp)
I wonder if there is a port on the tranny where I can get true real time line pressure?
09-08-2009, 10:32 PM #15
hey Ron, are you running an a4 or M6?
09-10-2009, 06:04 PM #16
M6, Heres what my tach/shift light setup looks like. There are 5 bulbs in the tach that light up progressively.
and heres the plate I made to fit over the cubby hole. Thats coming out, Im going to make a bigger plate... move the cigerette lighter... and put two guages there. Next to the Voltmeter will be my water temp.
09-10-2009, 06:43 PM #17
2 1/16 prosport gauges oil pressure and water temp
By RARON455 in forum Parts For Sale / TradeReplies: 5Last Post: 11-17-2011, 08:05 AM -
Help: water temp gauge
By 02_slp_ss in forum General HelpReplies: 4Last Post: 07-27-2010, 07:27 PM -
Water Temp and Oil Pressure Gauges
By Z28boy2000 in forum Parts For Sale / TradeReplies: 1Last Post: 07-14-2010, 08:16 PM -
on the water temp
By ledesma54 in forum GTOReplies: 0Last Post: 06-02-2008, 07:31 PM -
water temp gauge??
By 02sscamaro in forum General HelpReplies: 2Last Post: 06-16-2007, 12:45 PM
