Results 1 to 3 of 3
Thread: Comp Cams 292xfi???????
08-17-2006, 01:44 PM #1Junior Member
- FT WORTH
WHI- 96 BC4 CAMARO
Has Anyone Used The 292xfi Cam? This Is What Comp Cams Is Suggesting For My Lt1 In My Race Car. THE CAM HAS 242/248 584/579 AT 113 DEGREES. THIS WILL BE IN A 383 WITH TRICK FLOW HEADS WITH APPROX 11.2 TO 1 COMPRESSION.
08-18-2006, 03:47 PM #2Junior Member
- FT WORTH
WHI- 96 BC4 CAMARO
Any Help Would Be Appreciated. Thanks
08-18-2006, 05:17 PM #3
I guess this all depends on what kind of racing you're going to be doing. If your heads are being ported, it would be a good idea to work with the head porter, or someone with good LT1 cam knowledge, to pick a cam that works well with where your heads flow the best. The cam you posted is going to want to rev to make power. Make sure you have the gearing in the car necessary to take advantage of the high rpm power.
Comp Cams
By tg580 in forum General HelpReplies: 13Last Post: 04-22-2010, 09:47 AM -
Question: Comp Thumper cams
By turbodarryl in forum Internal EngineReplies: 5Last Post: 01-20-2009, 11:15 AM -
Fs Comp Cams Spring Kit
By bartolottaracing in forum Parts For Sale / TradeReplies: 1Last Post: 09-18-2007, 11:46 AM -
Comp Cams New Thumper Cams
By Z ROADSTER in forum Internal EngineReplies: 6Last Post: 08-27-2007, 12:39 PM -
F/S comp cams 216/588 114+2
By gen3performance in forum Parts For Sale / TradeReplies: 1Last Post: 06-23-2006, 11:54 AM
