Results 1 to 3 of 3
08-16-2006, 03:36 AM #1Member
- Clarksville, MD
Mystic Teal Metallic- 1995 Pontiac Trans Am
Video & Mp3's (Weird Noise) Wheel Bearing? Rear Dif? Suspension? Brakes?
As I was coming home last night I had a little too much fun and decided to do some burnouts and have fun on a curvy road. I've done both of these things before no problem. Now the back driver side wheel is making this noise:
mp3_1
mp3_2
3g2 movie of car going in reverse very slowly.
While I was going in reverse, I was going down hill and had the brake on for part of the time. The low traction light came on when it made the noise (kind of odd).
I took the car up to 50, and the problem seems to subside, but occur again when I use the brakes/and or brakes made the noise come back.
We just replaced the seal on the rear differential last Saturday but I do not think its a drivetrain related problem because putting the car in neutral does not make the sound go away, but higher mph makes the sounds occur faster, I think it happens once every revolution.
08-16-2006, 10:31 AM #2Detailing + Design
- Pittsburgh, PA
am i hearing it right? it's like a crumpling paper sound then a pop?
08-16-2006, 06:17 PM #3Member
- Clarksville, MD
Thats actually the wind. I fixed the problem, I didn't torque my lugnuts correctly and they loosened up over time. I am just lucky I didnt lose a wheel.
Intermittent grinding noise Wheel Bearing or Joint?
By florida4thgen in forum General HelpReplies: 11Last Post: 03-24-2014, 03:21 PM -
Weird noise! (Video)
By silverWS6 in forum General HelpReplies: 28Last Post: 04-27-2010, 10:28 AM -
Rear End Noise , Wheel bearing?
By gfeller2006 in forum DrivetrainReplies: 3Last Post: 04-24-2010, 01:42 PM -
Help: Starter fly wheel Noise Thrust bearing ? LS1
By mtotorica in forum Internal EngineReplies: 1Last Post: 01-25-2010, 02:52 PM -
Grinding Noise from Front Tires when turning sharply; Wheel Bearing?
By Thewilldog in forum DrivetrainReplies: 1Last Post: 02-24-2008, 10:18 AM
