Results 1 to 20 of 29
Thread: Weird noise! (Video)
04-18-2010, 11:12 AM #1
WTF is this noise? It sounds like a screech or something, at first i thought it was a pulley but then i checked it and nope it sounds like its coming from inside my intake Help! Anybody had this before? Is my intake cracked or something? Leaking? I don't see where this noise would come from. Idk if its just my crazy mind but i think its gotten worse and it started happening about 2 days ago
04-18-2010, 11:38 AM #2
if you intake was crack bad enough it would affect other parts and how the engine runs, your car would run lean and your idle wouldnt be steady, could it be injectors making that noise??? can you pin point where exactly its coming from?
04-18-2010, 12:51 PM #3
04-18-2010, 02:26 PM #4
- Jan 2009
- North Jersey
It almost sounds like when my idler pulley makes noise on humid/rainy days.
04-18-2010, 05:42 PM #5
- Apr 2008
- Madison, WI
Geez I don't see how that could be from the intake. Thats a crazy sounding noise. You could try taking the belt off and run it for a bit to see if its gone.
04-18-2010, 06:41 PM #6
- Ontario
White- 98 Firebird Formula
Do you have a check engine light on?
Had a similar sounds two years ago. Mine ended up being a dead plug, But I don't think that mine had the same screeching sound. Scared the crap out of me when it happened.
04-18-2010, 09:45 PM #7
04-18-2010, 09:50 PM #8
that is a crazy noise check your altenater when they get over stressed or going bad the diode in them make a screaming noise. I would bet its that or a solinoide somewhere
Let us know what it is when you find out
Owning a 9 sec ricer is like coming out of the closest: at first you'll surprise everyone, but in the end you're still gay
04-19-2010, 07:27 AM #9
- Jan 2009
- North Jersey
I forgot the possibility of a failing alternator.
04-19-2010, 08:15 AM #10
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
The screaming chicken is supposed to go on top of the hood, not under it.
I agree with Cutlass - remove the belt and see if the noise is still there. If it is then the next step would be as Devildog said, check the alt. Maybe even the power steering pump too.
04-19-2010, 09:12 AM #11
04-19-2010, 09:29 AM #12
04-19-2010, 10:04 AM #13
It is on the power steering/alternator side that the noise is coming from hmmm
Yup i removed my belt and the noise stopped so its gotta be my power or alt pulleys
Yes you do, easy 5 min job and the pulley is like $11 at autozone. Make sure you take yours in hand cause they'll probably the wrong one
I checked the a/c and it didn't change the noise at all.
If it was my power steering pump the noise would increase or decrease with turns, right? I'm thinking its my alternator, but would i have to replace my whole alternator or possibly just the pulley?
04-19-2010, 10:35 AM #14
04-19-2010, 12:59 PM #15
Sounds like an electrical interference in the alt windings. If ya dissassemble it I bet its got spots where the stator and armature have been shorting across each other. Either bad bearings or bad winding insulation is my guess.
04-19-2010, 01:03 PM #16
- Jan 2009
- North Jersey
When the alternator in my old car went, it sounded like one of those window-mounted A/C units. Got home and pulled off the belt and could not spin the alternator pulley. Got another and installed. Problem solved.
04-19-2010, 01:04 PM #17
04-19-2010, 02:01 PM #18
Well new alternator is on its way i guess. But if it was bad would it cause like my battery to die and such?
04-20-2010, 04:58 AM #19
- Apr 2008
- Madison, WI
In your video, I noticed a sticker on your power steering pulley. Is that pulley new?? If so, maybe its not press on all the way (or pressed on too far) which would cause belt misalignment and noise.
04-20-2010, 11:35 AM #20
no your battery wont die it wont get its full charge, cause your alt is still kicking out some juice now if you turn all your acceceries on and your brights you notice it
weird noise...
By Ramairgod84 in forum General HelpReplies: 4Last Post: 04-01-2010, 10:13 AM -
weird noise
By 02blackbirdws6 in forum General HelpReplies: 13Last Post: 04-05-2008, 02:50 AM -
Weird Noise
By tingo99 in forum Suspension and HandlingReplies: 5Last Post: 03-26-2008, 04:49 PM -
Weird Noise?
By vinnie311 in forum Firebird / WS6Replies: 6Last Post: 11-13-2006, 05:00 PM -
Video & Mp3's (Weird Noise) Wheel Bearing? Rear Dif? Suspension? Brakes?
By Marc1130 in forum General HelpReplies: 2Last Post: 08-16-2006, 06:17 PM
