Results 1 to 2 of 2
01-22-2010, 04:18 PM #1Junior Member
- Jan 2010
- California
Black- 2002 ws6
Starter fly wheel Noise Thrust bearing ? LS1
Thanks for taking the time to look,
Heres the problem : LS1 5.7 WS6,. As i was driving along it sounded like the starter started rubbing on the flywheel. The end of the bindex did show some wear as did the flywheel I have replaced the starter and made sure the flywheel was straight. The engine was still making the grinding noise. I am taking a guess that the thrust or third main bearing is worn causing the crankshaft to shift back and allow the flywheel to rub against the starter and thus the grinding starter noise. Could use a second opinion befor I pull the engine.
Thanks again Mike
01-25-2010, 02:52 PM #2
I would imagine for that to be happening you would have to have substancial movement back and forth in the crank. I would pull the belt off the front and then try to move the crank forward and see if that was possible. Normally the starter gear retracts pretty far back into the case.
Intermittent grinding noise Wheel Bearing or Joint?
By florida4thgen in forum General HelpReplies: 11Last Post: 03-24-2014, 03:21 PM -
Rear End Noise , Wheel bearing?
By gfeller2006 in forum DrivetrainReplies: 3Last Post: 04-24-2010, 01:42 PM -
thrust bearing issues
By 98redconv in forum Internal EngineReplies: 3Last Post: 01-22-2009, 02:30 PM -
Grinding Noise from Front Tires when turning sharply; Wheel Bearing?
By Thewilldog in forum DrivetrainReplies: 1Last Post: 02-24-2008, 10:18 AM -
Video & Mp3's (Weird Noise) Wheel Bearing? Rear Dif? Suspension? Brakes?
By Marc1130 in forum General HelpReplies: 2Last Post: 08-16-2006, 06:17 PM
