    Angry stupid a/c bolt is stripped
    I'm having an extremely difficult time removing my a/c pulley due to a stripped bolt. What the hell do i do to remove it? I'd like to avoid GM or a mechanic if possible. The bolt is a 13 mm, but the 13 just spins around it, and a 12 doen't fit. The bolt is also resessed into the pulley.
    Custom Car Emblems
    from third_shift|studios
    jaison tortorea
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Sears has a wide variety of tools for this purpose.
    Check them out.
    Minnesota
    1987 Trans Am
    Or you could hammer the 12m on the bolt.
    maine
    2000 ws6
    try to hammer a standard size on to it, you should be able to find one that almost fits but is just too tight.. The 12mm will most likely be too small to hammer on. Usually works for me and i just had to use this method on my atv. Also worked on my saturn when i had to remove the front engine/timing chain cover, i acutally just left the entire socket on there because it was some cheap tawain socket lol...
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    1/2" socket is slightly undersized on a 13mm nut. Perfect for this situation.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by 02z28ls1 View Post
    I wanted to say that!!!!!
    Bragg NC
    Met. Sunset Orange
    01 SS
    I agree with all of the above, either a "bolt out socket" i picked a kit up from sears, or just hammer on a smaller socket, since the bolt is "fubar" then get creative.
    J
  1. Help: Stripped Bolt Head
    By sparkman0034 in forum General Help
    Last Post: 12-21-2010, 05:27 PM
  2. stripped bolt thingy
    By Sas in forum Firebird / WS6
    Last Post: 03-08-2010, 06:41 PM
  3. Stripped torque converter bolt
    By 99formulals1 in forum Automatic Transmission
    Last Post: 12-30-2008, 05:56 PM
  4. Help: new 99 TA stripped out wheel bolt
    By Melos in forum General Help
    Last Post: 07-01-2008, 07:01 PM
  5. Header Bolt Stripped...
    By 001CamaroSS in forum External Engine
    Last Post: 04-24-2008, 06:52 PM
