Results 1 to 17 of 17
Thread: Stripped Bolt Head
12-17-2010, 01:13 PM #1
Stripped Bolt Head
My bird needs an oil change. When I started to attempt to DIY I noticed an issue, the head of the plug bolt is stripped, almost rounded.
Does anybody know how to get that bolt loose so I can change the oil and replace it? Being from AR redneck methods are naturally welcome. Just whatever works.
Thanks in advance
12-17-2010, 01:17 PM #2
Go to the auto parts and grab a new plug. Then take a set of vise grips to your old one..
12-17-2010, 01:18 PM #3
EDIT: ^^^^ beat me
Visegrips FTW.
What part of AR?
12-17-2010, 01:18 PM #4
Vice Grips and a mallet. Shouldve thought of that..
Thanks
12-17-2010, 01:23 PM #5
Should be able to get it with out the mallet.
12-17-2010, 01:31 PM #6
I've actually got a rounded bolt head on a 78 TA intake manifold and it's rusted in, any ideas.
12-17-2010, 02:11 PM #7
For the intake bolt try an overnight soak with lots of penetrating oil, then try the vice grips. A good penetrant like CRC or PB1 allowed to really soak for a while works wonders. Most people try to get by with WD40 but it just isn't the same in my experience.
If you can't get the vice grips in there try a slightly smaller metric socket that needs to be tapped on to the bolt head with a hammer or go to a well stocked tool store, they make some special sockets to grip rounded bolt heads.
12-17-2010, 02:51 PM #8
12-17-2010, 10:56 PM #9
12-18-2010, 01:33 AM #10
12-18-2010, 04:06 AM #11
I am a fan of using candle wax with the fire wrench. After warming everything up, touch a candle to the base of the bolt head and the wax will melt and wick into the thread. I used this method to remove the exhaust manifold bolts on our 40 year old Oldsmobile (no pun intended). Not even sure who taught me this trick, but it does work.
One other trick -- if the threads are seized too tightly for the bolt to unscrew, you can hit it with an air chisel. There is usually a blunt tip that you can place on the bolt head then let it pound away on it a bit. The intense vibration can help to break things free, especially after utilizing something like PB Blaster.
If all else fails, drilling out the bolt is about your final option. The key is center punching the head of the bolt and drilling down its center axis. I have found that if my center punch is off just a bit, a small piece of wood can be used to apply pressure to the side of the drill bit to force it on center as you start to drill. Start small and work your way up.
Once you have the center opened up a bit, you can then try an "easy out". It is essentially a sharp fluted tap that threads in counterclockwise. As it tightens, it grabs the bolt and tries to unscrew it. Word of caution -- do not break off the easy out by applying too much pressure or you will be really screwed. If it doesn't want to come out, simply up your drill size a bit more and as the wall of the bolt is diminished it will be more likely to come out.
12-19-2010, 06:48 AM #12
12-19-2010, 06:56 AM #1311 years of bangin gears
- Jan 2009
- North Jersey
All suggestions get my vote.
12-19-2010, 10:22 AM #14
I think I will have to go with liquid products first since there is no clearance on the manifold to get just about any kind of tool on the bolt.
12-20-2010, 07:40 AM #15
Saw on TV over the weekend that Loctite has a new product called Freeze and Release.
From there website: "Loctite® Freeze & Release instantly freezes seized and rusted bolts, nuts, studs down to -45°F (-43°C). This ultra shock-freeze effect causes microscopic cracks in the layer of rust, allowing the penetrating oil to wick directly into the rust by capillary action. The assembly can be easily dismantled after allowing only 1-2 minutes penetration time"
12-21-2010, 03:34 PM #16
12-21-2010, 05:27 PM #17
you could cut the head of the bolt pull the intake and use a stud remover on the rest of the bolt
Broken/Snapped/Stripped bolt head? Look here
By Hi-Po in forum ToolsReplies: 9Last Post: 02-17-2011, 09:59 AM -
stripped bolt thingy
By Sas in forum Firebird / WS6Replies: 25Last Post: 03-08-2010, 06:41 PM -
Help: Head bolts stripped
By Orrin's Z in forum General HelpReplies: 11Last Post: 08-10-2009, 10:22 PM -
Stripped Head Bolts
By surgitech74 in forum General HelpReplies: 8Last Post: 05-05-2008, 06:21 PM -
Header Bolt Stripped...
By 001CamaroSS in forum External EngineReplies: 3Last Post: 04-24-2008, 06:52 PM
