Thread: Stripped Head Bolts
05-02-2008, 11:39 AM #1Junior Member
- Jun 2007
- Albany, NY
black- 2002 Camaro B4C SS
Stripped Head Bolts
I'm in the middle of doing a head swap and one of the head bolts came out with some aluminum threads on it. Any ideas?
05-02-2008, 12:57 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
Helicoil.
05-02-2008, 03:40 PM #3Senior Member
- Apr 2008
- Madison, WI
A helicoil is not good enough for a head bolt. You need a Time-Sert. If you can't find the Time-sert kit/tools cheap enough, then ask your local Chevy, GMC, or Pontiac dealership to fix that hole. They most likely have the tools.
05-02-2008, 04:40 PM #4Exalted Cyclops
- Feb 2007
- San Diego, CA
Interesting. I'd not heard of these. They look pretty good. Check it out here: http://www.timesert.com/html/faq.html#1
05-03-2008, 04:08 AM #5Senior Member
- Apr 2008
- Madison, WI
We use them on Cadillac Northstar engines. They work great, but I had a few timeserts pull out. When that happens, then the block is F'd.
05-03-2008, 12:39 PM #6
If it pulled out you couldn't use one of the larger time-serts they were talking about in the video?
05-03-2008, 01:29 PM #7Senior Member
- Apr 2008
- Madison, WI
I haven't watched the video, but yeah I guess you can use one of the larger timeserts. I've heard of them but forgot about those. But those require buying an additional set of tools. We don't have those at our dealership because the tool set is so expensive.
05-05-2008, 01:01 PM #8Junior Member
- Feb 2008
- Southwest Oregon
light grey- 1978 Volvo 242GT
Sooooos, OK, I was wondering if the aluminimumumimmm blocks created any future potential issues regarding stripping out/wearing out the formentioned threaded bolt holes. Apparently sometimes. Is there any OTHER aftermarket support for salavaging such blocks by repairing/redoing the stripped threads?
I might/may be looking for an used LS engine and am also wondering if worn/stripped threads might be the reason the mill is for sale. Already learned about the piston slap problems----now apparently stripped threads in important places might also be a problem? Thanks for the input.
05-05-2008, 06:21 PM #9Senior Member
- Apr 2008
- Madison, WI
The Timeserts are a solid carbon steel insert. They are REALLY nice. You put them in with the really tough red Loctite and your good to go. But as mention they can pull out. Usually that happens more frequently when the proper procedure and tools aren't used.
Broken/Snapped/Stripped bolt head? Look here
By Hi-Po in forum ToolsReplies: 9Last Post: 02-17-2011, 09:59 AM -
Help: Stripped Bolt Head
By sparkman0034 in forum General HelpReplies: 16Last Post: 12-21-2010, 05:27 PM -
Help: Head bolts stripped
By Orrin's Z in forum General HelpReplies: 11Last Post: 08-10-2009, 10:22 PM -
One stripped thread during head install
By jfrc2000 in forum Internal EngineReplies: 8Last Post: 04-17-2006, 04:04 PM -
f/s AFR 205cc, head gaskets, and head bolts
By slimeball6969 in forum Parts For Sale / TradeReplies: 1Last Post: 08-12-2005, 09:17 PM
