Results 1 to 20 of 26
Thread: stripped bolt thingy
03-07-2010, 05:54 PM #1Member
- Jul 2006
- Loveland/Ft. Collins, CO
Blue- 2001 Formula Firehawk
I got my car in the air the other day and noticed a leaking power steering line. I'm trying to replace it right now, but ran into a snag. It looks like someone already tried doing this to the car, but with a cresent wrench rather then 18mm, so the lower bolt head is stripped. Is it ok to just cut the line and pray to get a socket on it, or should I try any other options first?
03-07-2010, 05:57 PM #2its short but its skinny.
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
can vise grips turn it? i dont know exactly what line you speak of so i cant recommend cutting it. if its a high pressure line that you are planning on re-using then i wouldnt cut it.
03-07-2010, 06:03 PM #3Member
- Jul 2006
It is the high pressure line, and I have the replacement for it as well. Trying to upload a pic of it now.
03-07-2010, 06:09 PM #4its short but its skinny.
- Oct 2009
pewter- 99 trans am
well if you must cut it to get it off, i say go for it, since you have the replacement hose. What do you plan on using to get it out of there since its stripped? small pipe wrench or vise grips should bite it good enough to turn it.
03-07-2010, 06:12 PM #5Senior Member
- Apr 2008
- Madison, WI
cut it and throw a socket on there. It'll come right out
03-07-2010, 06:14 PM #6Member
- Jul 2006
I was hoping to get a 32 point or whatever deepwell on it, but I just realized I bought the wrong one...
I know my tools, just not the proper names of them.
03-07-2010, 06:14 PM #7
03-07-2010, 06:15 PM #8
03-07-2010, 06:20 PM #9
Hose things down with brake clean first -- it certainly doesn't help having everything all oiled up.
03-07-2010, 06:23 PM #10
03-07-2010, 06:37 PM #11
03-07-2010, 07:13 PM #12Member
- Jul 2006
I just tried cutting the line, but realized I don't have anything that could cut it around here. I'm worried vice grips are going to damage it to much without getting it any looser. Found a pair in my truck that I forgot I had...
03-07-2010, 07:24 PM #1311 years of bangin gears
- Jan 2009
- North Jersey
Vice grips
Crow's foot socket in the needed size.
If all else fails, buy a replacement line and cut the old one with adjustable tubing cutter, hammer needed socket over stuck end of line and remove with ratchet.
03-07-2010, 07:28 PM #14
03-07-2010, 07:51 PM #15
03-08-2010, 06:38 AM #16Spaz is My Mentor
Wow what timing. I just posted something like this in my thread "stuck on side of road."
Be glad you got it now. I didn't see this leak and now it has killed my alternator and fried the battery as a good measure. I had to limp it home on a fresh battery. Parts are order. Besides the screwed up bolt any other problems? suggestions?
03-08-2010, 09:41 AM #17Member
- Jul 2006
Finally got the new hose on and been working at it a couple hours now. Penetrating spray is a must I've learned, it would have had the thing off last night. The fluid that came out looks clean, so I'm wondering, do I have to flush the system? I just noticed the clip is broken off what I think is the oil return hose (the rubber line coming off the drivers side bottom of where you fill it with fluid.) My hands are to big to get in there, so I'm not sure how I'd get it off.
03-08-2010, 09:44 AM #18
03-08-2010, 10:04 AM #19Spaz is My Mentor
did you have to pull the pump to switch the lines?
03-08-2010, 10:32 AM #20Member
- Jul 2006
No, but I only switched out the pressure line, I tried looking for the return line as well to do them both, but no place around even shows a power steering return line.
Help: Stripped Bolt Head
By sparkman0034 in forum General HelpReplies: 16Last Post: 12-21-2010, 05:27 PM -
Stripped bolt for coolant flush ????????
By brian r in forum General HelpReplies: 9Last Post: 06-22-2009, 07:40 AM -
Help: new 99 TA stripped out wheel bolt
By Melos in forum General HelpReplies: 4Last Post: 07-01-2008, 07:01 PM -
Header Bolt Stripped...
By 001CamaroSS in forum External EngineReplies: 3Last Post: 04-24-2008, 06:52 PM -
stupid a/c bolt is stripped
By third_shift|studios in forum General HelpReplies: 6Last Post: 08-13-2006, 11:56 AM
how hard is it to replace? hoping this isnt one of those "well if you have to ask then.." things
no you want a 6 point on that or in a pinch try a 12 point.
