Results 1 to 3 of 3
07-08-2006, 11:41 AM #1
cluth or tranny problem? Help.....
I have about 1K on mine and I think it may off blew up. The car is locked out of 6th and when in neutral and I let off the clutch it bogs out like its stuck in gear. If I put in gear and let off the clutch nothing happens the car just holds its position. Some times if I put it in gear it has a hard getting out, its getting stuck utill I force it out. My question is what do you think the problem is, the tranny or clutch.
07-08-2006, 02:23 PM #2
No one can has any ideas on what the problem might be.
07-18-2006, 07:57 PM #3Junior Member
- Jul 2006
- Possum Squat, Ky
'02 blue, '85 black&gold- 02 Firehawk #723,85 T/A
Mine was locked in forth from shifting hard. Although I could move the shifter into 1/2 with some force to break it free, it was still in fourth. The culprit was a small snap ring (internal c-clip) at the end of the 5/6 rail inside the tailhousing which had popped out of its groove. Everybody should have a copy of the Tremec Service Manual(booklet). If you open the tranny make sure to replace the 3/4 shift fork with a steel piece. The bent aluminum part will also cause missed shifts/popping out of gear. Have fun.
cluth problem??? transmission problem???? please HELP!!!
By adamblake97 in forum Manual TransmissionReplies: 3Last Post: 04-07-2014, 07:34 AM -
is it a clutch problem, or a tranny problem?
By sgt0704 in forum Manual TransmissionReplies: 3Last Post: 01-07-2007, 04:03 PM -
tranny problem?
By BlueByU-SS in forum Camaro / SSReplies: 0Last Post: 10-01-2006, 10:51 PM -
Tranny problem?
By GottaHaveLS1 in forum DrivetrainReplies: 3Last Post: 04-08-2006, 08:39 AM -
problem with tranny (i think) need help!!!
By baseballss in forum Manual TransmissionReplies: 4Last Post: 11-24-2005, 03:08 PM
