04-04-2014, 08:34 PM #1
cluth problem??? transmission problem???? please HELP!!!
I have a 97 trans am aftermarket stage two clutch,I don't know what's going on. my trans is shifting fine but once in gear and this is through every single gear when I get on it real hard is just redlines IN GEAR! it feel almost like the tires are spinning in the back and I have hardly ANY acceleration. is this a transmission problem? or clutch problem? my clutch has been acting weird every time I let of the clutch and drive it smells like a burning clutch smell but I'm not burning my clutch trust me. something is wrong, please someone tell me what they think this is.
04-05-2014, 08:12 PM #2
Sounds like the clutch is too loose. You have to look at what you installed. Did you surface the flywheel? Did you install a spacer? Did you get the right clutch?
04-06-2014, 11:22 AM #3Senior Member
- Mar 2009
- pompano beach florida
- 2002 Camaro Z/28 Pewter
What do you mean by too loose? If he torqued everything down it should be loose on the flywheel and if it was would make some awful noise. Op said in another thread he resurfaced the flywheel. Also apparently has 7k on the clutch so it should be the right one. A slave shim or spacer would only cause issues with it disengaging as it wouldnt push the PP far enough in. OP says its a spec unit which are known to sometimes have issues, clutch is slipping plain and simple. whether its caused by a bad PP failing disk or flywheel is something hes going to have to pull the tranny and see
04-07-2014, 07:34 AM #4
yea my clutch is slipping bad, coleman taylor is gonna pull out the trans and see what's wrong but the thing is i wanna know if it could be slipping for a simple reason like alignment or a bearing. or if i need the whole clutch replaced and resurfaced flywheel
Question: Transmission Problem
By Sickls1 in forum Manual TransmissionReplies: 22Last Post: 05-03-2011, 08:06 AM -
cluth or tranny problem? Help.....
By JD_Z28 in forum Manual TransmissionReplies: 2Last Post: 07-18-2006, 07:57 PM -
need serious help with my transmission problem
By degenerate in forum Manual TransmissionReplies: 3Last Post: 05-15-2006, 07:18 AM -
Transmission problem :(
By LSWONZ28 in forum DrivetrainReplies: 7Last Post: 02-24-2006, 05:56 PM
