Results 1 to 20 of 23
    1badls1 Sickls1's Avatar
    Dec 2010
    Las Cruces, NM
    1999 Pontiac Trans Am
    Transmission Problem
    I have a question about something that is going on with my 6spd tranny in my 99 trans am. Every time i try to race my second gear does not want to go in. When i am driving the car normal it goes in fine but everytime i push it hard it will not. I have been told that I might need a new master cylinder, but i really don't know. Can anyone give me any advice on what it might be and how i can fix this problem?
    Jan 2011
    South Carolina
    98 T/A
    Get an after market, adjustable M/C like one from Tick. That should fix what ales ya.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Is it only second gear and no other gear? Does second gear ever pop out of gear? Have you checked your fluid level? Is it nice and honey color or dark?
    How does your pedal feel? Normal?
    I would think if your MC is bad or your slave is on its way out, you would a) have a leak and be low on fluid and b) your clutch pedal would feel spongy, not return normal, or stick on occasion.
    Dec 2010
    Las Cruces, NM
    Yes it is only my second gear and my fluid is good I have a brand new slave cylinder on it and the pedal feels fine.
    Stock or aftermarket shifter? Sorry, this one has me a little stumped atm.
    The only thing that comes to mind is a) 1-2 bent shift fork (but this is uncommon in our cars) or b) bad synchro.
    My 3-4 synchro was fine while normal shifting but when I got on it in WOT, it would get stuck in gear. You are having engagement issues, which would still be a synchronizing problem.
    Dec 2010
    Las Cruces, NM
    It's a brand new GM slave cylinder
    I didn't ask about your slave, I asked about your shifter
    Dec 2010
    Las Cruces, NM
    i already had my tranny rebuilt, new shift fork and synchros were out in, and yes it has an after market shifter.
    Well, I am leaning towards a) your synchros or b) maybe your solid stops need to be adjusted some. I don't see why this would be an issue though if you are shifting fine at normal RPM.
    A clutch problem, a MC/slave problem would most likely result in ALL gears having an issue.
    Since yours is only in 2nd gear, I would think it has to be related to the shifter or internal working of the transmission.
    How many miles on the rebuild?
    Dec 2010
    Las Cruces, NM
    Less than 2k
    I'll let Cutlass make his assessment. He always pops in the manual transmission threads. You're going to have to wait some here buddy. I really think you have a trans issue though.
    Dec 2010
    Las Cruces, NM
    Alright thanks
    Just one more question, has it ever got stuck in 2nd? Like where you couldn't get it out of gear?
    Dec 2010
    Las Cruces, NM
    Once it got stuck in fourth and that's when it got rebuilt
    Well that was a 3-4 synchro issue...had the same thing happen to me. Hopefully Cutlass or someone else will have some additional feedback.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I'll assume everything inside the trans is fine, since it was recently rebuilt. That leaves a clutch disengagement issue. Which means, the clutch is still partially engaged when you are trying to shift WOT. And that why it feels like 2nd is blocked out.
    What clutch is in it? What Master cylinder are you using?
    Apr 2011
    Milwaukee, WI
    1998 Formula
    I have the exact same problem!
    He mentioned it is only 2nd gear though...could that still be the case?
    Madison, WI
    2001 Silverado Z71
    You are correct. A clutch disengagement issue would affect more then just 2nd...which the OP hasn't mentioned...yet.
  1. cluth problem??? transmission problem???? please HELP!!!
    By adamblake97 in forum Manual Transmission
    Last Post: 04-07-2014, 07:34 AM
  2. Help: transmission problem
    By my1stss in forum GM Trucks
    Last Post: 12-27-2012, 12:21 AM
  3. transmission Problem M6
    By 1999sscamaro in forum Manual Transmission
    Last Post: 11-06-2010, 09:17 AM
  4. Help: Transmission Problem only 2nd & 3rd ?
    By 99CANADAHAWK in forum Automatic Transmission
    Last Post: 05-25-2008, 01:07 PM
  5. transmission problem????
    By derbs in forum LT1
    Last Post: 04-26-2007, 10:21 AM
