Thread: Tranny problem?
04-05-2006, 05:26 PM #1
Tranny problem?
Several problems i've been havin with my drivetrain:
I was just peeling out around a corner and shifted into second and it grinded until i took it out. I was sure that i had the clutch to the floor and now when i downshift into second, i have to push much harder for it to go in. Another problem that i've been having, is every now and then when im at low RPM's and i downshift from 5th to 4th, it grinds for a second, then goes into gear. I also noticed that the fluid in the master cylinder resorvior was dark. The only reason i can think of that caused these problems was when I burnt the clutch badly when i was peeling out. I had only known how to drive a stick for probably a month, but i shifted into second while the tires were spinning and then into third. The clutch pedal felt like it lost pressure. The car reeked of a burnt clutch for a lil while and now my car does things that i mentioned before. Does anyone have any advice?Last edited by GottaHaveLS1; 04-07-2006 at 08:57 AM.
1999 Trans Am M6
SLP Short Throw, Lid and CAI, Strano Springs, Koni Sport Shocks, BMR STB and SFC, UMI PHB, Pacesetter LT's and ORY, Magnaflow Catback, DMH 3" E-Cutout, LS7 Clutch, Motive 4.10, 160 T-Stat, MSD wires,, 17x9.5 Chrome C6's wrapped in Hankook 275/40/17
Tuned at Mongillo Motors in New Haven, CT - 303 RWHP and 308 RWTQ
04-08-2006, 07:25 AM #2
You have one of 2 problems going on either a junk pressure plate from the heat of slipping the clutch or broken sicros. If it is the pressure plate not a big deal pull the trans and change the clutch and pressure plate and have the flywheel resurfaced. If it is the sincros then that is a bigger problem as the trans would have to be rebuilt and in my opion the sincros in the GM T56 are junk as well s the shifting forks but for a few $100 you can have a upgrade kit put in and not have any more problems. Good luck....
04-08-2006, 08:13 AM #3
This doesn't sound good... but thank you. It looks like i have somethings to look into now...
04-08-2006, 08:39 AM #4
Go to your local GM dealar and get a price on a GM 03' ZO6 clutch and pressure plate kit it will come with a new flywheel and all the parts needed to get the car back up and running. You will need a 26 spline clutch alinement tool other than that it comes with clutch disc pressure plate and flywheel. Oh and get a 01' Z28 slave cylinder also as it is much better than the 98-00.
Anyone Have this problem with A4 Tranny?
By 96Firebirdformula in forum LT1Replies: 6Last Post: 10-17-2007, 03:06 AM -
is it a clutch problem, or a tranny problem?
By sgt0704 in forum Manual TransmissionReplies: 3Last Post: 01-07-2007, 04:03 PM -
tranny problem?
By BlueByU-SS in forum Camaro / SSReplies: 0Last Post: 10-01-2006, 10:51 PM -
SERIOUS Tranny Problem! HELP!!!
By GTObsessor in forum Manual TransmissionReplies: 7Last Post: 10-25-2005, 06:19 PM
