Results 1 to 16 of 16
Thread: computer guru question? help
06-25-2006, 11:26 AM #1Member
- Sep 2005
- pa
black- Twin Turbo C5 Stroker WS6
Bought a new toshiba laptop..turned it on....removed AOL (i have verizon)...plugged in the dsl cable...internet works fine...removed cable...entered IP and Key...connected to wireless modem...connection excellent...bring up an internet explorer window...get the page cannot be displayed error no matter what site I try..
Any ideas? works fine hooked up direct. I have another laptop where I compared all the settings and everything looks good...but im a dumbsh!t when it comes to computers.
Thanks for the helpLast edited by Whocares; 06-25-2006 at 12:28 PM.
2001 C5 A4 1SC FE3 G92....STS GT32s Wilwood Brakes
1998 WS6 M6 Callies 383 stroker
2004 Avalanche Z71 4.10s, AR TTST 18s
06-25-2006, 11:57 AM #2
I get that a lot from my MSN. It has a 'troubleshoot' so I click on it it says proxy server. So I un plug my modem for a couple min . and then it works for a while. Might be something like that. I know the modem has to have the cache cleared every now and then ...
06-25-2006, 12:10 PM #3Junior Member
- May 2006
- Danville, PA.
Mystic Teal- 1997 Camaro Z-28
what brand router are u using? i have a linksys which i bought after my D-link finally took a shit. and the linksys is garbage. i had no problems with my d-link for about 6 years. great router, but everything is bound to fail at one point or another. my linksys always looses connectivy. and i hate it lol
06-25-2006, 12:24 PM #4
I have a Linksys. Sometimes it will go great then other times its not worth crap. Maybe I should swap like you did. Hom much did the D-link cost you ??
06-25-2006, 12:26 PM #5Member
- Sep 2005
- pa
its a Belkin wireless router...but my other laptop is working fine wirelessly. I must have a setting off or this laptop is different...XP vs windows 2000 on the other one.
06-25-2006, 01:03 PM #6Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Did you say you entered an IP address? You should set it to DHCP.
06-25-2006, 01:04 PM #7
06-25-2006, 01:26 PM #8
06-25-2006, 01:37 PM #9Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I think about the same 2 years
06-25-2006, 01:47 PM #10
I went to a review site for the d-links.. They only cost like $35, it had 10 reviews.9 of them was 9out of 10 stars , 1 had the dont buy it yadd yadda yadda ..
06-26-2006, 07:06 AM #11Junior Member
- May 2006
- Danville, PA.
i think a linksys router is kind of a hit or miss thing. it either works or it doesnt....my friend had the same problem with his. my dad is a network admin for the military and knows his shit. he told me to use nothing but d-link. not sayin that ed blown vert doesnt know what hes talking about either..but i personally have had nothing but problems with linksys and nothing but good internet connectivity with d-link...
06-26-2006, 12:06 PM #12Member
- DFW, Texas
Mystic Teal Metallic- 1998 Z-28, 2010 SS
I run a linksys at home. No problems here.
06-26-2006, 12:53 PM #13Senior Member
- Aug 2001
- San Diego, CA
383 w/Meth & ProCharger- 2001 Camaro Z28
It's possible your internet security settings are holding you back. On your browser window click on Tools-->Internet Options. Then go to the Security Tab and click the custom level button. You can set that to a lower security level or go through each each item and select enable. I highly recommend you have firewall protection because setting a lower security level will make you more vulnerable on the internet.
Also go to the windows update page and download/update "everything".
Good luck
I've heard linksys is hit or miss on how well it works. Personally I stay away from linksys, not bashing, just my preference. Right now I'm using Motorola cause I got it real cheap ==> $20. It's alright but that's all I can say about it.
06-26-2006, 04:56 PM #14Member
- Sep 2005
- pa
thank ntimid8r...here is what i get when I run a network test
test failed
not configured your computer to use the client adapter
use the network icon in the system preferences to set the network configuration for your client adapter
this is way over my head...im beating around all kinds of windows...
Any idea?
06-26-2006, 05:32 PM #15
did you go to majorgeek.com. buddy of mine told me about that site and it can answer anything...
06-27-2006, 06:28 AM #16Senior Member
- Aug 2001
- San Diego, CA
Yeah, you definitely have a network configuration problem. You can try using the "troubleshooter" to help go through some steps. Or do what Snaggletooth suggests cause you may need more help.
Go to your control panel and click on "Network and Internet Connections". On the left pane you should see the Troubleshooters area. Click on the "Networking" and follow the on screen steps. If that doesn't help then try the "Network diagnostics" troubleshooter.
Also you should be able to call your internet provider to help you go over the installation process.
Hope this helps.
Computer guru's inside..
By Danger731 in forum Computers / GamingReplies: 4Last Post: 03-04-2012, 12:39 AM -
Computer guru's inside !
By Danger731 in forum Almost Anything GoesReplies: 7Last Post: 12-26-2009, 04:23 AM -
website and computer guru's
By tomsws6 in forum Almost Anything GoesReplies: 6Last Post: 09-17-2008, 07:14 AM -
Computer guru's enter, need help
By grandkodiak in forum Almost Anything GoesReplies: 0Last Post: 03-02-2006, 07:44 PM -
Computer guru's needed, DSL question
By CaptainCaveMan in forum Almost Anything GoesReplies: 11Last Post: 02-17-2006, 12:05 PM
