    Aug 2000
    Indy
    Computer guru's inside..
    my last laptop died and i have the HD in an external HD case. Some files say i don't have permission to open like old dyno runs, birthday pic folders, old power points. I get Windows Media Player cannot access the file. The file might be in use, you might not have access to the computer where the file is stored, or your proxy settings might not be correct.
    Another is something about checking permissions. The HD is a xp but I'm using Vista. Isn't there a blanket fix for this instead of monkeyin around with each seperate file ?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    There are only about 3 people on this site who are computer guru's. I haven't seen any of them posting lately. Might want to try an actual computer forum if you can't find your answer using Google.
    Regardless, free bump.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Sounds like you need to take ownership of the files.
    Right mouse click on the parent folder which should be users. Then permissions and then owner.
    Member krese's Avatar
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    Quote Originally Posted by Ed Blown Vert View Post
    exactly what i would say the issue is.
    Aug 2000
    Indy
    I eneded up goin properties, security, add myself again, check full control, apply, ok on each file. Took 2 hours ! ugh. Ed, I'll try that on any others I find, thnx..
  1. Computer guru's inside !
    By Danger731 in forum Almost Anything Goes
    Last Post: 12-26-2009, 04:23 AM
  2. Computer / printer guru's inside !
    Last Post: 04-24-2009, 08:31 PM
  3. website and computer guru's
    By tomsws6 in forum Almost Anything Goes
    Last Post: 09-17-2008, 07:14 AM
  4. computer guru question? help
    By Whocares in forum Almost Anything Goes
    Last Post: 06-27-2006, 06:28 AM
  5. Computer guru's enter, need help
    Last Post: 03-02-2006, 07:44 PM
