Results 1 to 3 of 3
Thread: Idle Problems
    Idle Problems
    i just did an engine swap to a 408 stroker motor everything is good but the idle. i was wondering if anyone knows how i can run the car with a good idle for now without tuning.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    good idle on a stock tune with a 408 isn't going to happen. what you can do to crutch it for now is open the tb blade more to bring the idle rpms up. you may also have to drill the bypass hole larger.
    Member Huskerz1's Avatar
    99 SS Vert M6
    Quote Originally Posted by mrr23
    He's right. I personally would not drill the bypass hole. Find a way to keep the TB blade open a bit more. Get to a tuner.
  1. How To Fix Idle Problems - Idle Time
    Last Post: 04-05-2012, 07:50 PM
  2. Help: idle problems
    By 00ls1TAWs6 in forum General Help
    Last Post: 03-26-2010, 05:01 PM
  3. Help: Idle Problems
    By chaosinfinite in forum Camaro / SS
    Last Post: 11-13-2008, 08:15 PM
  4. idle problems
    By cobra12345 in forum General Help
    Last Post: 10-29-2006, 08:50 PM
  5. 95 Z28 idle problems
    By Tothineself54 in forum General Help
    Last Post: 03-12-2006, 07:49 PM
