Results 1 to 3 of 3
Thread: 95 Z28 idle problems
03-12-2006, 12:03 PM #1Tothineself54Guest
im new so be gentle...made a few changes to stock LT1 , installed headers, did away with cat convertor and smog pump...runs fine when cold for about 10 minutes then loads up like its missing...new wires, plugs installed..
new O2 sensors as well....after it runs poorly at idle it wil start surging and if i increase rpm's it seems to run fine until the rpms get above 3 to 4 grand then it will act as if starving for fuel , but even the high rpm problem is not consistent, sometimes it runs ok , other times it starts the sputtering.
but main issue is after it warms up, runs fine when cold....
please advise as this is making me older and wanting to nuke the car.
one other note...when i backoff at high rpms sometimes it will backfire
Thanks....JP
03-12-2006, 03:42 PM #2Junior Member
- Nov 2005
- coral springs,florida
blue- 2000 firehawk
you said youre ignition wires are new so i assume that is not an issue; check inside youre ignition coil tower and make sure there is not any corrosion in there an orignal 11 year old ignition coil could be all that is wrong. if youre coil is clean, it can still be bad unless it is new or replaced recently. after ruling out the possibilty of a bad coil i would assume that youre opti-spark distributor is failing. this can be for a few reasons;first if it is original from old age,second if you have washed or hosed youre engine or driven through any deep puddles ; its not hard to get water in there and cause permanent damage to it. i am an pontiac mechanic and have replaced more of these opti-spark distributors than i can remember. these distributors are notorious for acting up intermittantly like you have described. if you are going to change it you have a few options original delco and accel, and msd, also offer a high performance opti-spark alternative to a stock distributor. also since youre distributor is under the water pump and the pump has to be removed for access make sure the water pump is not leaking coolant onto distributor before replacing it so it wont fail again anytime soon. good luck; its not as hard as youre headers were to install so you should not have much problems doing this job; if you have any other questions feel free to ask.
03-12-2006, 07:49 PM #3
MAF...opti
How To Fix Idle Problems - Idle Time
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-05-2012, 07:50 PM -
Help: idle problems
By 00ls1TAWs6 in forum General HelpReplies: 5Last Post: 03-26-2010, 05:01 PM -
Help: Idle Problems
By chaosinfinite in forum Camaro / SSReplies: 10Last Post: 11-13-2008, 08:15 PM -
idle problems
By cobra12345 in forum General HelpReplies: 1Last Post: 10-29-2006, 08:50 PM -
Idle Problems
By kaohi36 in forum Internal EngineReplies: 2Last Post: 05-17-2006, 07:45 AM
