How To Fix Idle Problems - Idle Time
Does your stock or mildly modified Pontiac engine idle higher than it should because each time you try to dial it down, it runs rough?
Does your stock or mildly modified Pontiac engine idle higher than it should because each time you try to dial it down, it runs rough? If so, this article is for you. Weâ
More...
