Results 1 to 11 of 11
Thread: sfc bolt in/weld.
05-12-2006, 04:41 PM #1
sfc bolt in/weld.
well the welded one are always cheaper so if i bought the weld ones and drilled the proper holes and then bolt them in i would be cheaper in the long run ,has anyone done this before thanks billyb.
05-12-2006, 10:13 PM #2Member
- Boulder, CO
Black- 2000 Camaro SS
I would recommend just getting somebudy to weld them. Might be cheaper now, but doing it right now will save you money in the long run.
05-12-2006, 10:22 PM #3
Weld in are cheaper. Bolt ins are easy. I havent seen any studies on it but im sure weld ins are stronger but at the same time I doubt that much stronger. Plus I dont like the idea of welding a non stock part to the car. thats just me though.
05-14-2006, 02:24 PM #4
bolts-ins only connect to two places on the car for each side. over time, they will shift around and elongate the holes they mount to. weld-ins connect all the way down the side of the car on each side where it's welded to. no movement. the more the connection points, the stiffer the car will be.
05-14-2006, 02:32 PM #5see you in my rear view
- Apr 2006
- Boiling Springs SC
Pewter- 2001 WS.6 Trans AM
If you weld in the SFC's how difficult is it to drop your exhaust in the event that you might want to change to another system? Or the driveshaft?
[B]2K1 WS.6 m6: SLP Lid, MAF, smooth bellows, Y-Pipe, Loudmouth, 160 Stat, TB bypass, TR Velocity Stack, SLP Short Throw, K&N, Taylor 10mm wires w/ iridium NGK plugs, and 255lph F/P, Comp Cam, Chromemoly Rods, Comp Valve Springs
05-14-2006, 02:36 PM #6
your basic SFC are two bars going down the sides of the car. they go under the door rails under the car. unless you get something like the double diamond, there is no issue.
05-17-2006, 04:38 PM #7
i just ordered these by RK sport
http://www.LMPerformance.com/3717/1.html
how do they attach, do they weld right on?
06-01-2006, 08:37 AM #8Did you install these yet? Did you notice a difference? I just ordered a set today!
Originally Posted by ss~zoso~ss
06-01-2006, 02:41 PM #9
i'll be able to tell you next week, the car is still in the shop
06-01-2006, 02:42 PM #10
from what i've heard its night and day diff. i wont know exactly because i'm getting the MAC panhard put in to, so i wont know which is making more difference, but i'm willing to bet the SFC's are gonna do much more for me
98' SS Convertible Camaro-76k-Build # 1471, Cragar SS rims, RK SFC's, MAC Panhard, LSX Tune, Shaner S3,
SLP:short thro,Strut tower brace,fan switch
MTI Power induction kit,40 Series muffler,Pacesetter LT's + ORY,12 CD changer,3800lbs
http://www.cardomain.com/ride/787506/1
06-10-2006, 12:45 PM #11Junior Member
- Apr 2006
Yea so can anyone testify that the 2 point subframe conectors will make a noticable differance because i have heard that they are very good and will also cure the wondering feeling when your driving. thanks
Bolt-In vs Weld-In
By Naaman in forum Suspension and HandlingReplies: 16Last Post: 06-08-2010, 01:35 AM -
SFC Bolt-on VS. Weld-in
By joliver2 in forum Suspension and HandlingReplies: 65Last Post: 01-26-2009, 07:33 AM -
Bolt in/ weld in sfc
By speedracer25f in forum Suspension and HandlingReplies: 8Last Post: 09-11-2008, 08:12 PM -
bolt or weld exhaust?
By beer in forum External EngineReplies: 8Last Post: 06-15-2008, 06:26 PM -
Weld in or Bolt on SBC's?
By Nate00SS in forum Suspension and HandlingReplies: 3Last Post: 05-05-2006, 10:01 PM
