Results 1 to 20 of 66
Thread: SFC Bolt-on VS. Weld-in
11-23-2008, 09:03 PM #1Junior Member
- Mar 2007
- Kentucky
Pewter- 2000 Camaro SS (SLP)
Heres the deal. I just do daily driving so I dont feel that I need 300+ dollar SFC's so im trying to go thre cheap route. I can get J&M Weld-in connectors for 124 bucks shipped and UMI bolt-on for 175 shipped. I assume that I can do the bolt-in ones myself but I have no idea how to weld so the question is. Would it cost more than 50 bucks (the difference in price between the two) to pay a body shop to weld the SFC's in?
11-24-2008, 06:37 AM #2Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
You have to think down the road that they will bend or rust or both then bolt on would be the better choice
11-24-2008, 07:44 AM #3Junior Member
- Aug 2007
- So-Cal
Navy Blue- 1998 Camaro SS
11-26-2008, 04:24 AM #4
Or if you just like to climb under the car once a month and tighten them back up OK!!
And if you go to the track ........ about every third pass!!!
11-26-2008, 04:40 AM #5Member
- Feb 2008
- NEW JERSEY
I check mine when I change my oil they are never loose and requier now adjustments
11-26-2008, 04:40 AM #6Member
- Feb 2008
- NEW JERSEY
no sorry its early
11-26-2008, 05:24 AM #7
I've my bolt on sfc's on for 6 months with multiple times at the track and they are as tight as when i first bolted them on.
Personally i wouldn't want the weld-on's because what if you want to sell the car. OR more importantly like stated above, what if they rust or bend. just my .02 cents
11-26-2008, 05:57 AM #8Member
- Dec 2005
- Cedar Rpaids,IA
Red- 1998 Camaro SS
I've had my boltons for 3 years now and have never had to tighten them. Tho I did go to Fasten-All and got top quality bolts, lock washers, and nuts to install them.
1998 Camaro SS Hard Coupe Bright Red #1593
Mods: Lots!!, still my daily driver except for winter
383rwhp 370rwft/lbs
1979 Corvette
Mods Lots!!, weekend cruiser
325rwhp and 320rwft/lbs
2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
Mods: Catback, BFI CAI, Winter daily driver
11-26-2008, 08:14 AM #9
Well I guess he could just put bolt on's and if he has the same prob.
just have them welded to fix the prob. (it fix mine
11-26-2008, 09:17 AM #10Member
- Feb 2008
- NEW JERSEY
What kind of bolt on sfc did you have this problem with also how much power are you puting down
11-29-2008, 11:10 AM #11
just putting in my $.02 im a trained welder so i know abit on that end i was always told that its worse to put holes in the metal and bolt things together because moisture gets in the holes and creates rust and weaken ur holes over time. a weld if done properly will only create surface rust and if ur sfc's bend u shouldnt have put them on the car in the first place. just a thought i dont favor either way more just something to think about
11-29-2008, 04:15 PM #12Member
- May 2008
- connecticut
do you have to drill holes for the bolt ons?
11-29-2008, 04:21 PM #13
Mine were welded on! I like them as is... but who knows down the line!!!
They sure made a bid difference.
I could have went either way?
11-29-2008, 05:04 PM #14
this is lame, you should do a search. both tighten the same for your needs. bolt ons need to be checked for tightness. weld ons are a permanent
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
11-29-2008, 08:12 PM #15
i know what ure sayin danger but i was actually needing to ask something about bolt on vs. weld in as well:
Is it hard at all to line up a weld in set of subframe connectors? My buddy said he was gonna get the bolt on's and just weld em in instead because he didn't want to mess up lining them up, but from the ad it seemed anyone could line em up.. What should i do in that regard, my ultimate goal for this car is maybe low 400s at the wheels and as for now it has 386rhwp, so it's nothing really really intense. What do ya'll reccommend?
11-30-2008, 08:03 PM #16
I have bolt on, only had to tighten them once. I like the setup because I can take them off someday if I sell the car. Some people might be turned off from an SS that has stuff welded to it. Just my thoughts, good luck though!
12-01-2008, 05:31 AM #17
alright just to let everyone know i have never put in sfc's but i will some day and i will probably go weld in jus because i love to weld and i work for a suspension parts vendor that u all know so its not like i know nothing on the matter but different people want different things and i know i will never sell my car so i dont mind welding things in. when it comes to bolt-on's vs. weld-in i think that can only be decided by what u wanna do with the car down the road. like if u wanna sell it or not.
12-01-2008, 06:04 AM #18Member
- Feb 2008
- NEW JERSEY
My bolt ons bolted to existing holes in the body
12-01-2008, 06:35 AM #19
i'm thinkin i'll go weld in with these, i don't think i'll ever sell the car lol
12-01-2008, 07:08 AM #20- STOCK ish -
- Apr 2008
- Fairhope, Alabama
Black- 2002 Camaro SS SLP
Isnt bolt on's easyer? If you cant weld.. then u would have to pay for someone to do it.
So in the end isnt bolt on's cheaper too? Im bout to do bolt on's.
2002 Camaro SS A4 - SLP# 2951 l MS4 l LT's w/ORY l F.A.S.T 78 & TB l Borla l Cutout l CME l TCI 3500 l 3.23's l !emissions l !sway
Bolt-In vs Weld-In
By Naaman in forum Suspension and HandlingReplies: 16Last Post: 06-08-2010, 01:35 AM -
Bolt in/ weld in sfc
By speedracer25f in forum Suspension and HandlingReplies: 8Last Post: 09-11-2008, 08:12 PM -
bolt or weld exhaust?
By beer in forum External EngineReplies: 8Last Post: 06-15-2008, 06:26 PM -
sfc bolt in/weld.
By billyb in forum Suspension and HandlingReplies: 10Last Post: 06-10-2006, 12:45 PM -
Weld in or Bolt on SBC's?
By Nate00SS in forum Suspension and HandlingReplies: 3Last Post: 05-05-2006, 10:01 PM
