    Junior Member Nate00SS's Avatar
    Loveland, CO
    2000 SS
    Weld in or Bolt on SBC's?
    Just wanted to see what you all thought. Are Bolt on's as rigid as the Weld in's? Obviously the weld ins will be stronger, but will the bolts ins perform the same?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    the only issue with bolt in subframe connectors is over time, they will elongate the holes where the bolts go in. you only have four points where the sfc actually connect to the car. some have bought bolt ins, then welded them in place.
    ruff ruff rotwiler's Avatar
    WA State
    LT's, 3400 stall, FIPK,CB
    2002 Z28
    I have bolt in double diamond 3 point SFC's.. Have had them on now 20k+ miles and 200+ times down the 1/4 mile track and zero problems. I'm only running mid 12's, if I ever decide to add a cam and around a 100 shot, I think I will get them welded in.
    Marylang
    2002 Camaro SS
    When installing SFC's do you have to load the suspension or not?
  1. Bolt-In vs Weld-In
    By Naaman in forum Suspension and Handling
    Last Post: 06-08-2010, 01:35 AM
  2. SFC Bolt-on VS. Weld-in
    By joliver2 in forum Suspension and Handling
    Last Post: 01-26-2009, 07:33 AM
  3. Bolt in/ weld in sfc
    By speedracer25f in forum Suspension and Handling
    Last Post: 09-11-2008, 08:12 PM
  4. bolt or weld exhaust?
    By beer in forum External Engine
    Last Post: 06-15-2008, 06:26 PM
  5. sfc bolt in/weld.
    By billyb in forum Suspension and Handling
    Last Post: 06-10-2006, 12:45 PM
