Results 1 to 3 of 3
05-12-2006, 11:06 AM #1Junior Member
- Dec 2005
- Katy
Burgandy- 2002 TA
Help with 95 Camaro headlight switch
I am trying to wire a 95 headlight switch into a 69 Firebird, so I need to identify what the wires on the 95 switch are for.
I tried testing the switch last night with a battery and a test light.
I assume the 10-12 gauge red wire is the main power wire, but it could be the same gauge white wire. With either the red or the white wire connected to the positive battery terminal and the test light connected to negative, none of the other wires were hot when the switch was in the park lamp on setting or the headlamp setting. Is this a bad switch?
What are the small blakc, orange, tan, and brown wires for? When the switch was turned to the headlamp on if the red wire was connected to positive the white wire was hot, but none of the other wires had power....
HELP! I'm trying to wrap up this dash swap!
Drew
05-18-2006, 08:00 PM #2
Check this out, it's out of the service manual.....
http://shbox.com/1/headlight_chevy_1995.jpg
zoom in on it to read it.
05-19-2006, 04:35 AM #3Junior Member
- Dec 2005
- Katy
Burgandy- 2002 TA
Thanks! that's exactly what I needed!!!
Question: Bad headlight switch?
By JayTA98 in forum General HelpReplies: 9Last Post: 06-19-2013, 12:22 PM -
Question: headlight switch
By transamgirl89 in forum Camaro / SSReplies: 11Last Post: 08-08-2010, 09:42 AM -
Wanted: Headlight Switch
By Lightft01 in forum Parts Wanted / TradeReplies: 2Last Post: 03-25-2009, 09:12 PM -
Headlight Switch
By 99blueLS1 in forum General HelpReplies: 3Last Post: 03-23-2007, 06:34 PM -
95 Camaro headlight switch wiring
By Drewhelm74 in forum Stereo and ElectronicsReplies: 2Last Post: 05-12-2006, 02:10 PM
