    Member transamgirl89's Avatar
    Dec 2009
    Dacula, Georgia, United States
    2001 RS Camaro
    headlight switch
    Ok stupid question. How do you manually turn on the headlights for these cars? I was driving in the rain the other day and the sensor that turns them on at night wouldn't let me turn them on cause it wasn't dark enough outside. I'm used to having the knob on my old Firebird and turning them on whenever I want. lol.
    SS Driver aerojt's Avatar
    Ohio
    1998 Camaro SS M6 #1871
    They automatically turn on. The parking lights are on full time. You can bypass them and make the switch do everything if you do some fiddling. Somebody will post the link here. I forget what it is now....
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by transamgirl89 View Post
    Isn't there a knob in your Camaro to the left of the gauge cluster? There is in mine.
    2018 Tahoe - Silver - OEM
    Vicksburg, MS
    2002 Camaro SS
    Turn the round, headlight knob, 2 clicks to the right. Headlights will me manually engaged.
    USA
    Velocity Yellow
    2008 Corvette Z06
    If you are not going to be helpful to the OP or feel the need to leave smartass remarks, consider this your warning.
    You've got one in your Camaro too
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    To the OP. I assume from the pick you found the switch. Is your switch working? They can break, which would give you no control over the headlights.
    Dec 2009
    2001 RS Camaro
    Quote Originally Posted by Z28_Driver View Post
    Yeah I tried that also and it didn't work. What do you do to fix it?
    Pittsburgh
    2008 Hummer H3
    As others have stated you should be able to just turn them on whenever. But not off when dark.. Releasing the parking brake will turn them on too if it's dark... Running lights come on no matter what..
    Pittsburgh
    2008 Hummer H3
    Wink
    You may have to replace the switch..
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    Thats the easiest thing to do if the switch failed. Should solve your problem.
  1. Question: Bad headlight switch?
    By JayTA98 in forum General Help
    Last Post: 06-19-2013, 12:22 PM
  2. newer headlight switch
    By chm2001z in forum Appearance Section
    Last Post: 02-06-2011, 07:45 AM
  3. Headlight Switch
    By 99blueLS1 in forum General Help
    Last Post: 03-23-2007, 06:34 PM
  4. Headlight switch for 2000 T/A
    By Fastcar in forum Stereo and Electronics
    Last Post: 07-17-2006, 09:09 AM
  5. Help with 95 Camaro headlight switch
    By Drewhelm74 in forum LT1
    Last Post: 05-19-2006, 04:35 AM
