Results 1 to 3 of 3
05-12-2006, 11:05 AM #1Junior Member
- Dec 2005
- Katy
Burgandy- 2002 TA
95 Camaro headlight switch wiring
I am trying to wire a 95 headlight switch into a 69 Firebird, so I need to identify what the wires on the 95 switch are for.
I tried testing the switch last night with a battery and a test light.
I assume the 10-12 gauge red wire is the main power wire, but it could be the same gauge white wire. With either the red or the white wire connected to the positive battery terminal and the test light connected to negative, none of the other wires were hot when the switch was in the park lamp on setting or the headlamp setting. Is this a bad switch?
What are the small blakc, orange, tan, and brown wires for? When the switch was turned to the headlamp on if the red wire was connected to positive the white wire was hot, but none of the other wires had power....
HELP! I'm trying to wrap up this dash swap!
Drew
05-12-2006, 02:07 PM #2Senior Member
- Feb 2006
- Orange County, NY
sent pm of wiring schematic
05-12-2006, 02:10 PM #3Junior Member
- Dec 2005
- Katy
Burgandy- 2002 TA
Thanks!
1668 camaro ign switch wiring
By new 1968 in forum General HelpReplies: 1Last Post: 05-29-2012, 06:45 PM -
lt1 fan toggle switch wiring
By 93TransAm in forum LT1Replies: 10Last Post: 01-01-2012, 03:17 PM -
4l60-e range switch wiring.
By littlecars in forum Automatic TransmissionReplies: 4Last Post: 11-28-2009, 03:47 PM -
Wiring for a headlight switch
By toadson in forum Parts Wanted / TradeReplies: 0Last Post: 05-30-2007, 08:59 PM -
Help with 95 Camaro headlight switch
By Drewhelm74 in forum LT1Replies: 2Last Post: 05-19-2006, 04:35 AM
