05-11-2006, 05:48 AM #1Junior Member
- Apr 2006
First time ever running the 1/4 mile.
Well guys i just ran my z28 i got 2 weeks ago at the track and let me tell you getting my 60 foot time down is a bitch as you know. all i have for mods is fra w/ drop in K n N and a tru dual exhaust with flowmasters n ws6 store short stick. i ran 2 13.7's with a 106 mph trap speed with a 2.3 / 2.4 60 ft time. i just couldnt lauch hard enough i couldnt figure it out.. but not to bad for my first time out i guess. its an 01 z28 6spd also.
05-11-2006, 02:37 PM #2
describe how you are launching the car. rpms you hold it at, how you release the clutch pedal and mash the gas pedal.
05-12-2006, 09:50 AM #3Junior Member
- Apr 2006
Basicaly i tried reving it to like 2900 and then i eased off the clutch and it gets traction then i go so i kinda bogged it like every time and then only one time out of my 8 runs i burned out to much because i kinda dumped the clutch. how do you launch?
05-15-2006, 05:40 PM #4
i have autos. what i tell people with manulas to do is hold the revs to about 2500 rpms. have clutch pedal travel up to where it barely engages the clutch and push enough to release. when it's time to go, let out of the clutch WITHOUT adding any gas. so long as you have traction, start rolling into the throotle as fast as you can without breaking traction. it'll take a couple of times to get the right rpms and rate of throttle pedal push. most that have done it this way ended up with 2.0-2.1 60ft by the end of the night. more practive and you'll see soem 13.3x times.
btw add your timeslip to the et listing so i can put you on the list.
06-07-2006, 03:44 AM #5
Ok I know Im gonna get burned for this.. but here goes..
I have a 02 WS6 M6
I leave at 6000 rpm (eeek) i dont dump the clutch , just kinda roll off of it.
The Car has LCA's and Drag radials. My 60fts are consistant 1.7-1.8's. Im spinning a little but not much.. im actually spinning the wheel inside the tire.. I marked it with some white paint.. It looks like it has at least gone 1 full revolution inside the rim after one pass..
I run between 10-12lbs of tire pressure depending on which track and the conditions.
I cannot strees how important Tire pressure is.. I never see a whole lot of advise on tire pressure when advise is given.
Even when I run street tires I get 1.9 60 Ft's running pressure at 18 to 20lbs.. A little more spin but hey what do ya expect?
My car has nothing more that a lid, catback, LCA's and Drag radials (MT ET Street radial).
Not syaing that anyother advise you may get is wrong, this is just what works for me and my car.
the best way to to experiment and see what works best for you!
Good Luck!
Steve
See Pic below
06-07-2006, 03:50 AM #6
PC Skills are a little off this AM
here it is..
06-22-2006, 05:17 AM #7Member
- Charlotte, NC
Black- BMW E39 540I 6 spd 4.4 V8
Where is that? Doesn't look like Mooresville or Shadyside...
Originally Posted by newguy WS6
06-22-2006, 03:15 PM #8
It was in Pageland SC. About 30 Min form Monroe
Steve
06-27-2006, 02:52 PM #9Junior Member
- Apr 2006
sorry about the late reply but ill put my time slip up as soon as i take a pic of it.
1/8th mile time
By dethinboots in forum GTOReplies: 11Last Post: 04-21-2015, 08:26 PM -
1/4 mile time
By dethinboots in forum GTOReplies: 22Last Post: 01-29-2013, 06:06 AM -
help with 1/4 mile time
By xup2speedx in forum Drag RacingReplies: 18Last Post: 07-14-2008, 04:42 PM -
1/4 mile time
By 01tao6gto in forum GTOReplies: 3Last Post: 10-29-2007, 01:15 PM -
First time running new LS6 (ZO6) motor in the 1/8 mile, need help
By mglangley21 in forum General HelpReplies: 3Last Post: 07-14-2007, 07:37 AM
