Results 1 to 20 of 23
Thread: 1/4 mile time
    Insurgent Hunter dethinboots's Avatar
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    1/4 mile time
    For some reason I believe I should be getting better than 13.65 to 13.88 range. And I'm only topping out at 99 to 103. Is this typical? Mods below
    2005 Impulse Blue GTO
    Kooks Longtube Headers (off-road mids) , SLP Loudmouth II Catback, Vararam OTRCAI, MSD Spark Wires, 238/242 .595, Trickflow 225cc Heads, SLP 25% UD Pulley, Breather, Elite Engineering Catch Can, 3200 TC,Hayden Trans Cooler, P&P TB, Dyno tune by Sunshine Performance
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    What is your 60'?
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    I am def new to this. This being said, I have no idea lol.
    Do you have your time slip or no?
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    Did you spin a lot coming off the line? What kind of tires were you running?
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Oh okay I apologize. My 60 time is 2.2183 from a 13.72 run at 103.2
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    @FinZ28 I had some wheel hop and spinning. I'm running Nitto nt555 ZR 265/18
    Quote Originally Posted by dethinboots View Post
    Your 60' time is where you need to improve, but overall nice run. A lot of F-body's on stock set-up are able to get their 60' time down around 2.0. Some even in the 1.9Xs range.
    I understand the GTO is set-up differently though so that may be a contributing factor.
    With that said, for every 0.1 second you reduce off your 60' time, you will reduce your 1/4 mile time by 0.2. So, the ratio is 2:1.
    Example: If you were to run again and get a 2.0 (reduced by 0.218) 60' time, your 1/4 mile time would be roughly 13.28 (reduced by 0.436).
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Yes, but how do I improve on that time? I'm guessing this has a lot to do with traction, which i am not getting much of right now. Do you think drag bAgs would make much of a difference?
    Practice mainly. Leave at different RPM's. Use different tire pressures. Try burn out. No burn out.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    You have to get a feel for the car as it leaves. This is much easier with an automatic trans. What stall are you running. You should have 3400 to 3600 rpm stall. If you can hook and get it into the 1.9's I can see 12's in your near future.
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Thanks for the advice and confidence Everyone. I'll giv this some more time and keep y'all updated.
    Waiting on the Tree transamtom's Avatar
    Niagara Falls Ont.Canada
    1999 TA A4
    Remove your front swaybar that will give you more weight transfer to the rear wheels.
    Get some adjustable shocks to help with weight transfer.
    Run with 1/4 to 1/2 tank of premium.
    Get everything thats not nailed down out of the car,spare,jack ect.
    Get some Mickey Thompson Drag Radials they are the best hooking street tire.
    Once you learn to harness the power you have and start getting 2.0 and 1.9 60fts or better get a 3600 stall converter and cooler for your trans.
    You won't believe its the same car
    2010 Camaro SIM 2SS/RS A6
    1999 TA A4 NBM
    12.265 at 110.52mph
    Forgot to mention this earlier. That will destroy your rear end relatively fast.
    GTO's are notoriously tough to launch. It takes practice. Get that 60 down and your times will fall into line. My 04 went 13.69 on Kuhmo's with just a tune. My brother ran 13.40 in his 06 bone stock on street tires. Granted...those were both automatics so much easier to launch than your M6.
    1999 TA A4
    His profile on the left has IB 2005 GTO A4.
    I don't know why I thought he had an M6....I stand corrected.
    May 2011
    Fort Hood
    Impulse Blue
    2005 a4 GTO
    Remove sway bar? I don't know... Anyone else try this? Anyway, flooring it as soon as the tree lights isn't a good idea until I can harness it. Ideas?
    stall it up using the brake and then roll into the throttle...just try different things to get your best 60'
    Most people don't remove the sway bar. They just unbolt the one end so it becomes ineffective. As mentioned, this helps with weight transfer (allowing the rear to squat more during your launch). I don't recommend driving the car around without it though.
  1. 1/8th mile time
    By dethinboots in forum GTO
    Last Post: 04-21-2015, 08:26 PM
  2. help with 1/4 mile time
    By xup2speedx in forum Drag Racing
    Last Post: 07-14-2008, 04:42 PM
  3. First time down the 1/8 mile.
    By migueelw in forum Drag Racing
    Last Post: 06-19-2008, 01:04 PM
  4. New 1/4 mile time
    By Camaro9teen96 in forum LT1
    Last Post: 04-02-2006, 07:29 PM
