Results 1 to 19 of 19
Thread: help with 1/4 mile time
07-12-2008, 07:02 AM #1Junior Member
- Apr 2008
- cincinnati
mystic- 2000 trans am
i just ran my car at the track and was seriously let down. I have a 2000 trans am with slp cat back and slp induction package on it, also eibock pro kit other than that stock. Auto and i believe the 2.73 rear end. ran a 14.5 ...it was running kinda hot and sounded like the belt squeked at high rpms.....any ideas, is it just the rear end or what
thanks
07-12-2008, 07:15 AM #2
what was your 60' and mph? maybe spinning? what temp was your car running?
07-12-2008, 11:04 AM #3Junior Member
- Apr 2008
- cincinnati
60- 2.381 1/8-9.5 mph 101.20 car was at 220 so it was running hot didnt spin to much
07-12-2008, 11:09 AM #4
2.38 60'!!! thats your problem with your mods it should be about a 1.98! i would say get some DR's and get the temp problem fixed, maybe a 160 thermostat
07-12-2008, 11:15 AM #5
xup2speedx, Where did you run your car? Edgewater or Tri-State? If you ran last night then you went to Edgewater. Usually they don't prep the track much for test and tune nights.
Your 60' time is killing you....get some DRs and you will see your times come down. Your MPH is a little less then mine, but not much. Your car was running pretty hot. Your tensioner could be going bad.
Let me know the next time you go to the track..........I'll let you use my DRs.
07-12-2008, 11:17 AM #6
BTW I have a 00 WS6 A4 with a lid and a SLP LM1. I ran at Tri-State a few weeks ago......13.529 @102.59 with a 60' foot time of 2.088.
07-12-2008, 11:26 AM #7Junior Member
- Apr 2008
- cincinnati
hey guys thanks a bunch for these post i went to edgewater....yea im thinking it might be my tensioner going but would that cause it to heat up? im deft getting a 160 therm before i go coming up and im looking for a rear end. so u guys think with tires and new belt tensioner and therm i can get 13's
07-12-2008, 11:38 AM #8
just with dr's on a good stock car you will get 12's
07-12-2008, 01:31 PM #9
are you stalling it up any for the launch?
LS6 Engine swap, Custom Predator Tune, Lid, SLP Cold Air, Ram Air H.O. Hood, Hooker Long Tubes, !Cats, 3" True Duals w/Dynomax Bullets, Performabuilt stage 2 w/3600 stall, B&M Trans. Cooler, Moser 12 Bolt w/ 3.73's
Pics of my car
http://community.webshots.com/user/demonspeed_ta
07-12-2008, 04:29 PM #10Junior Member
- Apr 2008
- cincinnati
yea to about 1800
07-13-2008, 05:01 AM #11
When you leave at 1800 RPMs are you spinning? If so, try leaving at idle to see if that improves your 60' time.
Don't use a 160 degree stat in the Winter.....My 93 T/A would never warm up in the Winter, I would go with a 180. You might want to look into a SLP fan switch....it will help you cool your car down while you are waiting to run. You may also want to have your car tuned to have your fans come on sooner.
07-13-2008, 08:11 AM #12Junior Member
- Apr 2008
- cincinnati
what kinda shop do i need to find to tune it and also do i need a programmer?
07-13-2008, 10:51 AM #13
daves total proformice is the most populer but cincy speed can do it to. are you runing with your tc on thats the same time i ran with it on. eadgwater dosnt prep the track it sucks thats y i like tri-state beter. on a good day my 01ta with a cat back and lid runs 13.5 at 105mph. my best is at killkare in dayton with a 13.3 at 107mph. let me know next time you go also thare are about 3 of use that go down from time to time, we will try and met you thare.
07-13-2008, 05:57 PM #14
theres definatly something wrong my 90 mustang GT ran a 14.6 you should be running about 13.4 and ur trap time is good for 13's get that belt checked out and the overheating thing but I wouldnt worry so much about a tune get all the other stuff checked out first ive seen bone stock trans ams running low 13's without a tune just in good running condition....
07-14-2008, 07:36 AM #15
07-14-2008, 02:08 PM #16Junior Member
- Apr 2008
- cincinnati
well i dont have the traction control option witch i thought was kinda odd but yea im going to get a thermostat and take a look at the belts and try another run maybe easing into the throttle off the line
07-14-2008, 02:19 PM #17Senior Member
- Nov 2006
- Indianapolis
Not an A4 with no stall and 2.73s it won't.
My '98 ran a best of 13.69 @ 102.95, usually it was right at 14.0 @ 100-101.x. I had to manually shift just before the rev limiter, my 60 foot was usually a 2.0x. You need to get traction on the launch. A good stall will get almost .5 I have learned from this site. Of course, with a manual you can get any stall you desire.
07-14-2008, 02:27 PM #18
07-14-2008, 04:42 PM #19
yeah i gained a little over 4 tenths i think, close to that its been a while
1/8th mile time
By dethinboots in forum GTOReplies: 11Last Post: 04-21-2015, 08:26 PM -
1/4 mile time
By dethinboots in forum GTOReplies: 22Last Post: 01-29-2013, 06:06 AM -
First time down the 1/8 mile.
By migueelw in forum Drag RacingReplies: 0Last Post: 06-19-2008, 01:04 PM -
New 1/4 mile time
By Camaro9teen96 in forum LT1Replies: 1Last Post: 04-02-2006, 07:29 PM
