    columbia, sc
    2001 camaro z28
    Angry Check Gages Light...
    My light is coming on and the oil pressure goes past 60 when I'm driving and it's alittle right between 40 & 60 at idle. Should I be concerned?
    Member 5LtrBtr's Avatar
    Oklahoma
    01 Trans Am
    Thats very good oil pressure, so don't be concerned about that. The check gauges light is also a low fuel light.
    Wichita, Kansas
    yellow
    2002 TransAm collector ed
    Many parts stores have OBD2 scanners and they'll help you for free. So I'd go there if you arent low on fuel and the light is still on.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by notsomellow
    the check guages light doesn't throw codes that can be scanned, it's just a reference that something you can monitor in the guage cluster is outside preferable parameters.
    Are you sure the oil pressure being high is the only problem? Do you change your filter every time you change your oil? Do you ever have junk in the oil when you change it that could be clogging oil passages and inhibiting flow?
    NY
    1999 Chevrolet Camaro Z28
    Anything that goes in the red zone on the gauges such as:
    Too low or too high amp from the alternator
    Low fuel
    Engine temp overheating
    Oil pressure too low or maxed out.
  1. gto check oil light
    By iamoscar in forum General Help
    Last Post: 04-17-2011, 01:40 PM
  2. Question: "Check Gages" light flickering on and off
    By pdiddyz28 in forum General Help
    Last Post: 08-06-2010, 03:06 PM
  3. Service Engine Light...and check gages
    By NHBighead in forum External Engine
    Last Post: 03-29-2009, 11:35 AM
  4. Check engine light
    By CDBROWN in forum Firebird / WS6
    Last Post: 05-15-2008, 12:04 PM
