08-05-2010, 04:53 PM #1
"Check Gages" light flickering on and off
recently the "check gages" light has been flickering on and off,so i look at the gages and only thing thats out of place is the Battery gauge is constantly going from 13 which is good to 8 which is in the red.it's a brand new battery i bought last year,could it be the alternator? Cuz the power steering pump was leaking for a while which as you all know is right above the alternator.also the "high beam" blue icon is always light now too?
thanks i appreciate all the input!
08-05-2010, 05:22 PM #2
Low voltage can cause a variety of problems. Get the alternator checked.
08-05-2010, 05:55 PM #3
Check your connections at the battery and your grounds as well.
08-05-2010, 06:17 PM #411 years of bangin gears
- Jan 2009
- North Jersey
Is your battery a Delco? The negative terminals tend to fall out of the battery itself. Not to mention leak all over the battery tray.
08-06-2010, 12:15 AM #5
Yep ^^^
I had a Delco until recently and my Neg. terminal quite literally fell out, too!!
There was evidence of a previously "fudged" repair where you could see epoxy glue in the hole
Had to give in and get a new one (different brand) and trust me...over here in the UK your choices are really limited in side post batteries and costly also
I was advised to tighten lightly with a smear of petroleum jelly on the threads... worked well!!
Trev
08-06-2010, 12:33 PM #6
the battery i have is a Duralast Gold.i'll try to tighten the terminals.Any idea why the High Beam icon is lite also?i don't even have high beams cuz i changed the headlights to HID's last year and its just now coming on?
Thanks.
08-06-2010, 12:39 PM #7
08-06-2010, 01:36 PM #8Senior Member
- Jul 2005
- Jacksonville, FL
Most likely the alternator, but won't hurt to remove the battery and take it back to where you bought it for a free load test. Make sure the battery is a minimum of 690 CCA.
08-06-2010, 03:06 PM #911 years of bangin gears
- Jan 2009
- North Jersey
Leaky power steering pump above alternator=FFFFFFFFFFUUUUUUUUUUUUUUUUU
Grand Prix GT "check engine light"
By rschap1 in forum Almost Anything GoesReplies: 3Last Post: 10-24-2008, 06:20 PM -
"Check Gauges" light on
By 1TA LS1 in forum General HelpReplies: 5Last Post: 09-07-2007, 08:30 AM -
"Check Gauges" light on, how much fuel is left?
By amon37 in forum General HelpReplies: 10Last Post: 01-14-2007, 06:29 PM -
Check Gages Light...
By cool87gn in forum General HelpReplies: 4Last Post: 05-06-2006, 12:48 PM
your alt is shot... need to fix that leak asap cause you got a goo fire hazard going there...
