    May 2008
    Crowley, Tx
    Check engine light
    Ive been looking at GTOs for myself. Well lastnight I went to a dealer to look at a 04 GTO and found a 01 ws6 TransAm that my wife had to have. The car looks good and drives good so we bought. Tonight the ck engine light came on and I ck the codes. I got a code P1416 for the bank 2 AIR system. Does anyone have any info on this code? Thanks in advance for any help.
    Chase
    Member Cronex's Avatar
    Philadelphia, PA
    2001 Trans Am #693
    "P1416- AIR System Bank 2 is the 'air pump check valve' on the passenger side. Autozone has them for $10."
    "yep,
    P1416 is the air check check valve on the passenger side. They're cheep, replace both while you are doing it. The pipe and valve come off in one piece. Put it in a vise and twist the valve off and be carefull not to twist the pipe. After, reset the computer and you're done.
    have fun,
    Rob"
    ...both quoted from this sites thread : http://www.fbody.com/ls1/79808
    May 2008
    Crowley, Tx
    I was looking real close at the pipes after I posted the question and it looks like someone has replaced the valve already. How often do they go out?
    Thanks, Chase
    Philadelphia, PA
    2001 Trans Am #693
    One of the guys in that thread said they usually last 3-4 years.
    pix of wife and car
    Senior Member
    Jacksonville, FL
    If it was a GM dealership bring it back, or just clear the code/PCM and see if it returns. Not expensive and easy to replace yourself...think the going price for the check valve is higher than $10 now though.
  1. Check Engine light vs. Service Engine light
    By bigrig73 in forum Computer & Tuning
    Last Post: 04-20-2010, 07:11 AM
  2. Question: Check Engine Light
    By 550hpbird in forum Computer & Tuning
    Last Post: 02-13-2010, 05:07 PM
  3. Check Engine Light
    By SailorZ28 in forum General Help
    Last Post: 09-28-2007, 09:45 AM
  4. Service engine soon light = Check engine light?
    By jinxeng in forum General Help
    Last Post: 08-11-2006, 08:34 PM
  5. Check Engine Light has come on.
    By Jim_s in forum Camaro / SS
    Last Post: 11-11-2005, 02:00 PM
