    Jim_s
    Guest
    Question Check Engine Light has come on.
    My Check Engine Light has come on. My oil pressure, temperature and electrical gauges all look ok. I have also filled my tank with premium gas and have tightened the gas cap. However, the gas cap is not attached to the car by the strap any more. Has anyone had a similar problem.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    Lightbulb
    i've had a similar problem and it turned out to be my air pump
    the second time i threw a code for maf sensor and skip shift solenoid, and it was a short in a wire
    YOURE BEST BET IS TO GO TO AUTOZONE AND GE IT SCANNED AND THE CODE WILL TELL YOU WHAT IS WRONG WITH IT.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    scan it and post what it says..probably a p0420 or a p0430 code
    Import Killer SLP00blueSS's Avatar
    MIchigan
    mine came on it was the air pump, had the dealer re-set it and never came back on been about 5 months now
    Indiana
    2002 Camaro SS
    2 of my friends had the same prob. and like stated above it was the air pump. I had the prob. as well but I took my cats off but my Comp. fixed it
    2002 Camaro SS:
    383 Stroker Motor From DSE - 445HP
    Tremec T-6
    Moser Rear End - 373's
    A lot more, but wont Fit
    South of Heaven
    Navy Blue Metallic (NBM)
    2002 Camaro SS
    Ours is the annoying P1416 (air check valve voltage), and now P0140 and P0160 (removed the rear cats for LT/ORY installation)...
    Funny thing is the Cats are now throwing codes but the check valve is fine...
    It will all be tuned out anyway.
    LS1ROC
    Guest
    dude please have it scanned ...hell it could be anything....write back....
  1. Help: Check engine light on
    By Black WS-6 in forum Firebird / WS6
    Last Post: 09-18-2010, 03:06 PM
  2. Check Engine light vs. Service Engine light
    By bigrig73 in forum Computer & Tuning
    Last Post: 04-20-2010, 06:11 AM
  3. Question: Check Engine Light
    By 550hpbird in forum Computer & Tuning
    Last Post: 02-13-2010, 04:07 PM
  4. Check Engine Light
    By SailorZ28 in forum General Help
    Last Post: 09-28-2007, 08:45 AM
  5. Service engine soon light = Check engine light?
    By jinxeng in forum General Help
    Last Post: 08-11-2006, 07:34 PM
