Results 1 to 2 of 2
    2002 WS6 Trans Am
    LS1 to LS3 swap in 2001 Trans Am - PCV routing question
    We put an LS3 stock 430 HP crate engine into a 2001 Trans Am. Trying to figure out how to do the PCV system. Anyone done this?
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by austinWS6 View Post
    Should be the similar as the LS1 that you took out with a slight twist
    https://irate4x4.com/media/ls-pcv-routing-jpeg.81914/
    Picture to show valve cover vent tubes/ports/
    You should vent tube coming out of the valve covers, drivers' side should have an exhaust vent, same with passengers; unless there is a second vent tube on the back of the passenger cover, and or one from the "knock sensor plate", just route the lines to the PCV valve then to the throttle body.
  1. 79 trans Am LS3 swap.
    By SMWS6TA in forum LSx Retrofit and Swap
    Last Post: 01-08-2020, 11:06 AM
  2. ls3 swap in 02 trans am no power on bank 2
    By ls3ws6 in forum General Help
    Last Post: 11-21-2015, 04:11 AM
  3. Help: weird motor knock and modified pcv routing:VIDEO:
    By DaytonaBlues in forum Internal Engine
    Last Post: 10-09-2013, 02:35 PM
  4. LS3 Swap with manual Trans
    By millercamaro in forum General Help
    Last Post: 02-11-2008, 05:44 AM
  5. help! pcv tubes routing
    By astyles in forum External Engine
    Last Post: 09-08-2007, 02:45 PM
