Results 1 to 15 of 15
    Jun 2012
    indiana
    ls3 swap in 02 trans am no power on bank 2
    I swaped a ls3 into a 02 trans am and the coils on bank 2(2,4,6,8 cylinder) has no fire. Bank 1 fires fine. I have the correct 1x cam sprocet and the 24x crank. What could be the reason for this? Thanks
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Could be a number of things. Could be a loose harness that connects to the packs on the bank that is not firing, a pinched wire, a bad ground. Have you backtracked the wiring you connected?
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    definitely make sure you have all grounds connected
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Check and make sure the coil packs are plugged in firmly to the harness as well. It can look connected and not be, I had that happen last time I changed spark plugs, I removed the coils to get them out of the way, got in too big of a hurry putting it back together. Thought I had dropped something through the head, scared me lol. Definitely sounds electrical to me.
    Sent using my telèfono
    Jun 2012
    indiana
    Ok all the wiring is great and groumds are on good on the back of the head. To day it ran good on the side that wasnt firing then bad on the one that was good. It switched sides. Also my dome lights have been turning on and off randomly could this be vats or something?
    Oct 2009
    pewter
    99 trans am
    man it really just sounds like loose wiring somewhere to me....especially with the crazy dome light action....try running a direct ground to the chassis of the computer....i forgot a ground on the back of my engine when i did the swap and had to run a ground to the computer....now all is fine.
    Jun 2012
    indiana
    So put a wire from the ecu to the frame? What wouldnt be grounded good to make me have to ground the ecu to the frame?
    Oct 2009
    pewter
    99 trans am
    can never be too sure. it worked for me when i did my swap. not saying it will fix it but its worth a try. I ran a wire from one of the phillips head screws on the ecu to the fenderwell and my car started acting right.
    Junior Member Twixter08's Avatar
    Aug 2015
    Denison, TX
    2002 WS6 Trans Am M6
    Ever figure it out?
    The OP hasn't posted since September of 2012... not sure that he's still around to respond. That being said, I would be curious as to the cause of his issue - my guess would be a missing ground or a bent pin in a connector that wasn't making contact.
    Aug 2015
    Denison, TX
    Yeah same here, its why i asked even though its not been posted on in yrs lol.
    That's good - I was concerned that you were experiencing the same issue and was going to dig into the service manual if you were.
    Aug 2015
    Denison, TX
    Oh no lol im still on the ls1 block but thinking of buying a ls3 block to build up to get it ready for future, but thank you man! Very nice of you.
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    I remember, from my Pontiac dealer days, a few LS1 Fbody tow ins from time to time that had problems with mice finding injector and coil pack harnesses fairly tasty.
    That happened to our Regal Turbo while in the hands of the prior owner -- I found the injector harness taped together.
  1. Trans am running bad getting a po308 misfire code on bank 8
    By Street Fighter in forum General Help
    Last Post: 02-27-2016, 04:05 AM
  2. power antenna swap
    By fbodyNATION in forum Stereo and Electronics
    Last Post: 06-08-2011, 11:05 AM
  3. 99 Trans AM sSLP lid then bank 1 back 02 sensor
    By Durango in forum Firebird / WS6
    Last Post: 04-23-2009, 09:42 AM
  4. bank 1 bank 2 sensor locations?
    By Hector in forum General Help
    Last Post: 03-13-2007, 05:23 PM
  5. LS6 heads/cam swap how much power
    By FastRegalWE2 in forum Internal Engine
    Last Post: 10-16-2005, 03:40 PM
