Results 1 to 3 of 3
    poor bastard DaytonaBlues's Avatar
    Oct 2012
    Cape Cod, Mass
    99 SS clone M6
    Exclamation weird motor knock and modified pcv routing:VIDEO:
    i have a 99 Z28 ss clone. 119k miles, motor is all stock never been apart (stock except for a lid, FTRA and SLP cat back). the problem is i have a real loud clacking sound only from 1300 to 1800 rpm. in the video at around 1:06 you can REALLY hear the clacking sound. the motor is being held at around 1800 revs. I got no idea what the noise is but i can say it doesnt do it when the engine is cold, or when you go past 2 grand. motor does make a lot of valvetrain noise but it idles well and still pulls hard to 6000. It MAY have had a Predator hand held tune done but i dont know how to tell. I have a scan tool too but i dont know what the stock LS1 timing should be at idle, WOT etc..
    secondly, take a look at the PCV setup since i ripped out the old worn stock PCV valve boot and added a catch can (cheap can but better than without) along with the newer orifice style pcv valve. i dont know if theres a better way to route the pcv hoses and the valve as you see at the end of the video. (only 2 minutes long). the way i have it now is 3/8" hose from intake to the pcv valve end, then the valve sits in a sparkplug boot(so i can turn the pcv valve vertical like some suggested). from the sparkplug boot/pcv another hose to the catch can. the stock pcv hoses are still on the motor.
    almost sounds like an exhaust leak.
    I can't hear any metal ticking....
    Oct 2012
    Cape Cod, Mass
    99 SS clone M6
    at 1:05 or so into that video it sounds like my rockers are whacking against the valve cover (drivers side)...im glad you dont hear nothing bad. there is a bad valve clatter sound at 1800 rpm. bad enough you can hear with the windows up and over the drone of a Loud mouth exhaust..stationary holding the rpms at around 1800 its LOUD. i gotta drive this thing cross country too.
  1. lt1 acting weird (video)
    By Mike510 in forum LT1
    Last Post: 03-27-2011, 05:36 AM
  2. Weird noise! (Video)
    By silverWS6 in forum General Help
    Last Post: 04-27-2010, 10:28 AM
  3. Help: BAD knock...even when warm *VIDEO*
    By Rhinohuey in forum Internal Engine
    Last Post: 04-09-2009, 09:41 AM
  4. lol.... weird crash video..
    By bad boy 99 in forum Almost Anything Goes
    Last Post: 04-15-2008, 04:27 PM
  5. knock in motor????
    By sbpower72 in forum Internal Engine
    Last Post: 07-06-2006, 08:13 PM
