    Sep 2016
    Brooklyn
    Swap an f-body rear end into a G-Body car
    Has anybody swapped an f-body rear end into a G-Body car like a Regal
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    With enough work anything is possible but why?
    Sent from my HTC6535LVW using Tapatalk
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Would that be a downgrade, or a same-same as far as hardware and tolerances go?
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by Naaman View Post
    Unless the G body has an 8.5 rear (GN and some 442's), the G bodies use thte same 7.5 - 7 5/8ths that the Fbody uses.
    Better off getting a Strange or Moser 8.5 or 9 inch, with rear discs (if thats why OP wanted to swap).
    SLP Air Lid/Smooth Bellows
    Elite Engineering PCV Oil Catch Can
    SLP Smooth Air Lid and Smooth Belows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Dyno Dynamics dynoed @ 415 rwhp
    Weight reduction via removal of dead mice
    Member DarrenWS6's Avatar
    May 2015
    Blossburg, PA
    Silver Metallic
    2000 Trans Am WS6
    The best swap for the OE 10-bolt is the scrap yard.
    2000 Trans Am WS.6 M6
    SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
    Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
    YouTube.com/DarrenWS6
  1. G body ls swap
    By jking78 in forum General Help
    Last Post: 02-02-2015, 12:08 PM
  2. Help: F-Body V6 to V8 SwaP (Help PLZ)
    By Jager686 in forum General Help
    Last Post: 05-20-2011, 06:34 AM
  3. Question: Ls3 swap into 98-02 f-body w/ls1 currently
    By leonardTA1999 in forum General Help
    Last Post: 05-15-2010, 03:47 PM
  4. Question: LS3 swap ls1 f-body
    By BANDITO in forum Internal Engine
    Last Post: 09-23-2009, 03:18 PM
  5. Sup all!!! 03 LS 5.3 Swap in a G-body
    By Chris_SLPNElky in forum New Member Introductions
    Last Post: 05-05-2009, 12:43 AM
