    Junior Member leonardTA1999's Avatar
    Aug 2008
    OCEANSIDE
    BLACK
    1999 PONTIAC TRANS AM
    Exclamation Ls3 swap into 98-02 f-body w/ls1 currently
    Good day to all who read this.. and thank you..
    My question is what are the changes req for an ls3 crate motor from mast motor sports into an 1999 firebird trans am with an ls1 and t-56 in it now ?/
    you can look at the motor and all that it comes w at paceperformance.com
    under mast motor sports sub link at the bottom of there crate engines page..
    MTM111-210 - Mast Motorsports Turn-Key LS3 427 Cubic Inch Crate Engine - 600 HP
    everything i have now is bone stock as is from factory as far as the engine now. i just need input on the changes nesscary for this 427 ls3 to go in.
    like will all of the factory sensors and acc`s still work with threre supplied computer and harness and will my gage cluster still work?? and is the factory t-56 trans bolt to the bell housing of the ls3 and can i use my ls1 flywheel on the ls3 and does the pan that comes w this crate work in an f-body and can i use my ls1 oil pan on the ls3 block.. see where im going with this ??
    any help would be very much appreciated thank you..
    Cpl Leonard J Ray usmc
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    the ls3 will go in and blot to the trans fine. im not sure of the flywheel or the gages. the pc and harness will for sure need to be replaced to fit the new moter. and the pan need to be canged to fit the k-memer if i remember right. if you look online one of the mags did this swap and if i can find the mag i will post it for you.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Aug 2008
    OCEANSIDE
    BLACK
    Quote Originally Posted by 01 t/a View Post
    the ls3 will go in and blot to the trans fine. Im not sure of the flywheel or the gages. The pc and harness will for sure need to be replaced to fit the new moter. And the pan need to be canged to fit the k-memer if i remember right. If you look online one of the mags did this swap and if i can find the mag i will post it for you.
    thanks a mill ur info is priceless and much appreciated...
    Cpl leonard ray
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    you need to make sure the reluctor wheel tooth count is the same. also the ls3 is a drive by wire...unlike our ls1's run by cable....also you will need a big time tune..
    Junior Member Thunda's Avatar
    Albany,Ga
    2001Ws6 TransAm
    check gmperformanceparts.com and look at the E-Rod LS3 crate engine. It has the ECM and Harness
    2001WS6 T/A slp lid, smooth bellows, Taylor Thundervolt wires, Bosch+4, Vig 3200 stall, BM trans cooler, SLP 3" Y-pipe, 3" corsa catback, preditor custom tune by RWTD, 275/17BFG'S. 1976T/A 455-4spd-3:42
  1. Swap an f-body rear end into a G-Body car
    By Carmine lucchese in forum Firebird / WS6
    Last Post: 09-07-2016, 01:38 PM
  2. G body ls swap
    By jking78 in forum General Help
    Last Post: 02-02-2015, 12:08 PM
  3. Help: F-Body V6 to V8 SwaP (Help PLZ)
    By Jager686 in forum General Help
    Last Post: 05-20-2011, 06:34 AM
  4. Question: LS3 swap ls1 f-body
    By BANDITO in forum Internal Engine
    Last Post: 09-23-2009, 03:18 PM
