Results 1 to 3 of 3
Thread: G body ls swap
    Junior Member jking78's Avatar
    Jan 2014
    G body ls swap
    I have a question for my gbody guys with the ls swap done. Can I just buy a grand national sending unit and use my malibu gas tank or do I need to buy both sending unit & gas tank
    The G-body and LS1 fueling systems are completely different as far as pressure is concerned. Your best bet to retain the stock style tank these days is probably to run the Aeromotive drop in pump assembly that will seal to a stock tank (after some work). Even though I own a Turbo G-body, I cannot remember if it has a return or returnless style pump setup.
    Jan 2014
    I'm not to sure if I can use a malibu tank because it's not set up for a efi pump. It would be cheaper if I could you my old tank and drop a grand national or a 4.3l monte carlo sending unit with a walbro 255 pump
  1. Swap an f-body rear end into a G-Body car
    By Carmine lucchese in forum Firebird / WS6
    Last Post: 09-07-2016, 01:38 PM
  2. Help: F-Body V6 to V8 SwaP (Help PLZ)
    By Jager686 in forum General Help
    Last Post: 05-20-2011, 06:34 AM
  3. Question: Ls3 swap into 98-02 f-body w/ls1 currently
    By leonardTA1999 in forum General Help
    Last Post: 05-15-2010, 03:47 PM
  4. Question: LS3 swap ls1 f-body
    By BANDITO in forum Internal Engine
    Last Post: 09-23-2009, 03:18 PM
